Nose and tail fuze has nothing to do with delay. The delay is either electronic (in the case of the FMU 149 series fuse (fitted to the tail), or explosive in the case of say the M904E4 type fuze (fitted to the nose). Having the Fuze in the tail has nothing to do with the delay, and much more to do the the type of the fuze, and what you might like to attach to hte nose. FOr expamle LGB kits or ground proximity sensors.
In the mechanical fuze (M904) there is a delay element that is inserted into the fuze. it is an aluminium cartridge, about half the size of a C cell battery. There are a range of delays available, from .25 to instantaneous.
In the electronic fuze like the FMU 149, the delay is selected by rotating a little knob on the fuze. Depending on the capability of the Fuze function power supply in the aircraft, the pilot has the option of selecting different fuzing options in flight. this is acheived by supplying either +ve or -ve voltage to the fuze. Th fuze will then set itself to the preselected delays .
There are two different delays built into a fuze. There is the arming delay and the functioning delay.The diference between arming delay and funtioning delay is simple. The arming delay is the time taken from the bomb’s release from the aircraft to the time the fuze is armed. This means you are not flying around with an armed fuze in your bomb, which is not a safe situation. This delay is pretty critical for low level release, drop the bomb too low and the fuze will not have had time to arm itself. The bomb is armed in two ways - Mechanical fuzes have a brass arming wire that acts a bit like a pin in a grenade. It is attached to the aircraft pylon and runs through the fuze vane. When the arming solenoid is activated the wire will stay with the aircraft (hopefully,) as the bomb falls free the wire is pulled out of the arming vane and the vane is free to spin. If you need to jettison the bomb safe, you deselect the arming solenoid and the wire stays with the bomb. With electronic Fuzes this is all done with electrical volatage. As the bomb is released, the electrical cable between the bomb and the aircraft starts to pull tight. Just before it breaks, another shorter cable attached to a safety switch (Mk122 Safe arm defice or SAD) is pulled out, opening the circuit for the voltage to reach the fuze. This happens when the bomb is about 6 inches clear of the pylon, and deffinately on it’s way.
The functioning delay is the time between the bomb hitting the ground and the fuze functioning and causing the bomb to detonate. This controls the amount of penetration achieved.
The arming delay on mechanical fuzes is controlled by the number of turns required of the arming vane. On the electric fuzes it is again a setting on a little knob on the face of the fuze. for example, 2.4/inst means 2.4 seconds after leaving the aircraft the fuze is armed, and inst means as soon as it hits the ground it goes bang.
All this info related to how we used to operate with the A4K in RNZAF service, but is typical of other Fuze sydsems used in the MK 80 series and other weapons.
