Ok, an update… I got the Eduard kit going for the “Before They Were Aces” GB as Bud Anderson’s 1st “Old Crow” and the Monogram kit as my Uncle John’s Cactus AF P-39 for Stikpusher’s Gudalcanal Campaign GB…
The work started in the cockpit as usual, here’s some pics… I drilled out the holes and added sprue bolts for the IFF box behind the armor since the Stateside birds didn’t have them installed, but left the PE cable for it for visual interest. I also used the PE panel, but ended up redoing the gunsite as I didn’t care for the look of the kit supplied one(Shown here)… The seat-adjustment lever on the right side there is stretched sprue, since the kit part shot out into space on me during installation… The seat is a resin one that was supplied by my Secret Santa last year (who also gave me this kit. I never could have afforded this one)
!(http://img.photobucket.com/albums/v233/HansvonHammer/Screenshots/Models/P-39 GB/AndersonP-39002.jpg?t=1262784467)
!(http://img.photobucket.com/albums/v233/HansvonHammer/Screenshots/Models/P-39 GB/AndersonP-39006.jpg?t=1262784543)
Now, on to the wings…
Adding the interior parts for the intakes, along with the PE screens turned out to be a waste of time as A: You can’t see the screens, and 2: They ( the intakes) cause the upper wing halves to set too high up to close, even with clamps… So, I got out the trusty Dremel and ground off the tops of the intakes (shooting one of the screens into the Hinterlands in the process) which allowed the wing halves to close… Still had to use a skoshi bit of putty though.
There was a pronounced gap in the left wing/fuselage joint, which I filled with a little bead of Testor’s Putty, thinned with alcohol. I later cleaned out the panel lines that got a little putty in 'em and also filled those shrinkage cracks… I also had to fill the joint at the top of the carburator air intake and reshape it a bit due to the fuselage halves being one shorter than the other…
The right wing joined nice & tight, but on the underside, the joint between the trailing edge of the flap and the fuselage was pretty wide, so it got filled as well and I also cleaned out the flap/fuselage joint…
!(http://img.photobucket.com/albums/v233/HansvonHammer/Screenshots/Models/P-39 GB/P-39004.jpg?t=1264118982)
!(http://img.photobucket.com/albums/v233/HansvonHammer/Screenshots/Models/P-39 GB/P-39002.jpg?t=1264119648)
!(http://img.photobucket.com/albums/v233/HansvonHammer/Screenshots/Models/P-39 GB/P-39003.jpg?t=1264119275)
Couple of things about this kit… There’s some alignment issues, namely the fuselage halves… The left one is shorter that the right (about q milimeter), meaning I had to sand the rudder’s trailing edge to match the right, and this is what caused the gap in the flap/fuselage underside joint… Also, the trailing edges of the wings are way too thick and I should really have sanded them thinner… I was just too lazy to do it, heh… As they are, they look about a scale one or two inches thick…
Overall, I’m not all that impressed with the Eduard 'Cobra over the Monogram/Revell version so far, and I’m not saying it because of my well-known bias towards Monogram… BUT… You’d think that with the price of Eduard’s 1/48th kits, it’s gonna be a better fit than the Revellogram, but I’m not seeing it… Sure, there’s a bit more detail in the 'pit, the wheel-wells are nicely done (I screwed up on those, BTW… I’ll write about THAT later, heheh…) and there’s the TON of PE fiddly bits ( I’ll never use 80% of 'em) and pre-painted (WTF?) panels, handles, knobs, levers, harnesses, and decal selection, as well as round and flattened tires (dunno why there’s round ones), but that’s not really enough, IMHO… Glad I didn’t pay for this one, if you get my meaning… I think a higher-end kit like this should fit better and the moldings should be a bit crisper & thinner (especially the wings)… I don’t know if this is a warpage-prevention issue (The Monogram wings are little bit warped due to the thinness,out at the tips, but easily clamped. Could also be due to the kit’s age & how it was stored)
Also, one last BIG gripe… There were NO clear parts in the kit when I opened it (Thankfully, a fellow forum member, who asked to remain anonymous, sent a spare one to me) and I can’t find the left stabilizer… (I don’t know if I lost it or it was just never there, so I’ll not take Eduard to task for that part)… I never heard back from Eduard about the clear parts and it’s been over a year since I wrote them too… The missing left stab will be a pain, but I can cast one in resin, I reckon… (Unless someone out there has a trashed 1/48th Airacobra of any make ? Hint-hint…)
Well, thanks fer readin’ & I’m off to the Monogram kit again…
