I rejoined the hobby a few years back and when I was a teen I had a basic single speed Dremel rotary tool and a Dremel motor speed controller. I recently purchased a Dremel 100 single speed tool and also a universal motor speed controller. Although the Dremel works setup with the speed controller it will not go to anything but the highest speed. I thought at first it was the extension cord and tried with plugged directly in the socket and same problem. Then I pulled out my 40-year old Dremel speed controller and it worked but had that same issue of not go to anything but the highest speed. It definitely did not have this problem when I was younger. I do not have my old Dremel tool, but I have to assume that the issue is with the tool not working with a speed controller but not sure and would appreciate any suggestions, ideas or other rotary tools (Dremel or other brand) that would work with a speed controller. Thank you in advance for any and all help.
on your external speed controllers, do they have a rotary speed dial with 0 to 5 or 6 printed on the controller face? i presume you played with the dial for different speeds but just got high speed only, correct?
forgot to add this link on the specs of your Dremel tool. https://us.dremel.com/en_US/products/-/show-product/tools/100-series-rotary-tool
Seems most likely to me that your external speed controller has failed. Those things are realatively cheaply made, and they don’t last forever. I had one, but that was way back in the 1960’s. If yours is of that vintage, as Bones would say, “It’s dead, Jim!”
PS: On second reading, I see you recently purchased this equipment. I would contact Dremel for a possible replacement under warranty. They are a reputable company.
Or maybe the speed controller is made for a tool with a DC motor in it and the dremel has an AC motor in it…
Good luck with your tools and have a nice day
Paweł
Paweł, i don’t think that is the problem as old Dremel controller does same thing as new controller.
Thanks Chuck
Yes, that is correct and when I dialed lower than the highest setting it quickly turned off. Do you think I have a defective Dremel and need to contact them as I cannot think of any other solution? Thank you for your interest in helping me, really appreciate it.
Thanks
yes in contact Dremel & tell them what is happening & what you did to show it is the tool that is the problem not the controllers.
Thanks, I really appreciate your multiple comments helping me!
no problem.
