After building several airplanes in a row it’s time for some armor. I started this while waiting for my North African Sherman to arrive.
This is an early D pre zimmerit. Either going to be Kursk or GD right after Kursk.
It’s a premium kit so lots of PE and extra metal bits. PE usually frustrates the heck out of me but this has been ok so far. Got the running gear done and the rear bulkhead.
Both boxes done. The jack mount will go on at the end.
Very nice Satch! I’ve got this kit and started it about 3 yrs ago and never got past the suspension. Its still sitting in the box waiting for attention and now it will be jealous because I’ll be paying more attention to yours than my shelf queen!! [:P] Are you building it as a Kursk vehicle?
Ah yes, those instructions. I’m curious to see what you think of them. Myself I don’t much care for them. I did a Panther with that type and now working on a T34/76. The T34 sheet is missing part numbers, incorrect part numbers, drawings that don’t match what’s in the kit…thank goodness for Perth Reviews to help me along.
These instructions stink. Prefer the newer Dragon line drawings. You really have to be careful to do all the sub assemblies separated out in the instructions. Most of them are optional PE mini kits to supplant the plastic parts.
Got a little bit of work on on the Panther.
After test fitting and manipulating the superstructure and the hull, I decided to mate them prior to putting on the fiddlybits, contrary to the instructions. I found that I have a tendency to break things when handling them.
Don’t know if I misaligned the rear bulkhead or if it just had bad fit but that is the only problem area so far. The rear bulkhead to rear engine deck and the fit of the sponsons to the bulkhead/storage boxes. Lots of glue and squeezing and I got it pretty much joined.
Thanks Bil for the tip on the cupola. You’re right, big seam. Green putty and Mr Surfacer took care of that.
This often happens with the Premium type kits that receive an upgrade treatment but still have much of the originally molded parts still around. The picture-style instructions thankfully died out relatively quickly as DML’s method and they went back to the line drawing approach…but they still surface again now and then in the Premium kit treatment. You do have to be extra-vigilant as they will show things installed suddenly and not always with a call-out number! Looks like you’re making good progress with this one satch, glad to be help with the cupola tip. [Y]
I have a resin Panther D storage set so I think I can hide that rear deck gap under a box. A little green putty filled the front corner plate gap. The gap between the sponson and the rear storage box will have to do. Hopefully no one will be lifting the tail of my panther to check it’s sex!
Assembly is pretty much done except for the running gear. The road wheels are all cut and cleaned read for painting. Now working on the tracks.
I’m using Bronco workable tracks on this one. The Magic tracks don’t require cutting and cleaning but do require glue and are not left/right tracks that Panther’s had.
I left most of the tools off until after painting. The torsion arms are not affixed yet, that’s why some are missing. I’m debating whether to mount it on a base and articulate some of the road wheels.
First time I’ve used Bronco tracks and it’s a good news bad news thing. Good news is they are accurate and don’t need glue. Bad news is they are attached to the sprue and require cleanup ala the old Dragon indie links.
Using a sprue cutter, my first few links left big nubs that were impossible to file. They attach in a concave part of the link so a flat file or sanding stick won’t work. I tried a rounded file but it didn’t work well either. Finally I just used a #11 blade to dig out the nub.
I then tried cutting from the side at an angle matching the concave link.
Much better results as you can see here.
Instructions say 86 links per side. There are 8 sprues of 12 so 7 + 2 should do it. Keep slogging along…
Important safety tip campers. Bronco Panther Early tracks do not fit on Dragon Panther D drive sprockets. There four days of my life I’ll never get back.
Oh no! [:XX] What a bummer! I saw all the work that needed to be done to cleanup and was thinking of magic tracks. Sorry friend, hope it works out for you in the end.
I think this has do with with the Dragon sprockets, not the tracks? If I recall correctly, doesn’t that kit instruct you to use track links from the kit sprues to go around the sprockets, whereas the rest of the track uses the Magic Track links that come with the kit?
