hello, when i go to attach the road wheels to my firefly i am unsure about what to do can any one help?
Can you clarify your problem? Your post is unclear.
the parts have a wierd fit so i am unsure about what to do, di i sand of the molded on circle and bar on the back
I built one of Dragon’s Fireflys awhile ago and didn’t experience any trouble with the wheels. I’m wondering if perhaps you are trying to attach one of the spares to the bogies. If I recall correctly the spares had a plate and bolt molded in the center on one side of them to simulate a front slope mounting. Check your parts carefully and make sure you’re using the correct ones. If you’re using the correct pieces then try to explain more clearly what the trouble is and run it past us again. It’s a Sherman, it can’t be too hard.[:)]
Need a picture here…
DISASTERMASTER
