Greetings friends.
Never posted a WIP here before but there’s a first time for everything. Seeing the works of others has prompted me to illustrate this build for you - so you can learn what (and what NOT) to do if you decide to build one of these kits.
This kit is a re-pop of the Hasegawa Sabre family. It can either be built as a Canadair Sabre 6 or as a North American F-86F-40 Sabre.
This is the 48th scale Revell of Germany Canadair CL-13 Sabre 6 as flown by JG 71 ‘Richtofen’ of the Luftwaffe in 1961. It will be finished with kit decals. Not sure how they’ll turn out but we’ll see. Paints will be Model Master enamels and Alclad II. I’m not sure if this Sabre was ever retrofitted with the Martin-Baker ejection seat. I’m building it as if it hadn’t been.
Sabre 5’s delivered to the Luftwaffe carried the standard RCAF three colour camouflage; RAF Dark Green / RAF Dark Greay and RAF PRU Blue. The Sabre 6’s delivered from Canadair we natiral metal and the camo colours were applied by the Luftwaffe. Research shows that the colours I should use are RAL 6014 (Gelboliv), RAL 7012 (Basaltgrau) and 7001 (Silbergrau). The cockpits were painted in FS 36231 by Canadair.
The only aftermarket I’ll be using in this build is a Legends seat. As noted by Theuns in his Sabre build (and the approximately 20 or so others that I’ve built!), the kit seat is sorely lacking detail. The seat will be installed after painting the camo colours.
The rest of the cockpit are kit parts including decals for the IP. Painted flat black and clear coated with Future. Kit decal applied over Future and a healthy dose of Solvaset used to get things to settle down over the raised detail. Various knobs were picked out with red paint on a toothpick. There is ample room atop the intake trunking to superglue some weight to prevent the kit from being a tail dragger. I didn’t paint the interior of the intake trunk or exhaust nozzle. I use the kit supplied FOD covers painted red. It provides a nice contrast and a bit of extra colour.
Also, all Canadair Sabres were built without the bump / bulge at the vent on the top of the fuselage by the vertical tail. To model a true Canadair Sabre, this bump has to be sanded off. Further, the Hasegawa Sabre family has a vent moulded on the right side of the aircraft (as viewed from above) and this vent is unique to Japanese Sabres. I had to sand off both bumps and vents. The vent is filled with styrene, sanded, filler applied and sanded smooth with 400, 800, 2000 grit wet / dry paper. The bulge was sanded off with various grades of sanding sticks and then smoothed with wet / dry paper.
One of the differences between the Sabre 6 and the F-86F-40 is the length of the wings. Although both had leading edge slats, the F-40 wing has a 12" extension between the tip of the wing and the end of the aileron. The Sabre 6 had no 12" extension and the aileron extended all the eay to the wingtip. In order to model a Sabre 6, you need to cut off the 12" extensions and the glue the Sabre 6 wingtips into place. RoG provides resin or plastic wingtips for this. I used resin. It does take a bit of work to get them right. I glued the tops to the bottom and used a razor saw to make the cut. I then CA glued the tips on and applied a bit of accelerator when I was sure I had things where I wanted them.
As for the canopy, I use EZ Masks. They’re made by a company just outside Ottawa. One of my LHS’s carry them and they’re great. Like Eduard, they’re pre-cut vinyl. Here they are masked and primed with FS 36231.
That’s it for now. I look forward to any comments or constructive criticism you might offer.
Thanks for looking.
