I finally got around to making a wet palette today and I am kicking myself for not having done it sooner. It worked amazingly well and kept my paint wet for literally hours.
Yes, it’s an invaluable tool, especially when painting figures.
For those who don’t know what a “wet palette” is, it’s essentially a closable tray with a layer of absorbent material soaked in water covered by a semi-permeable liner on which you put your water-based paints. Water from the lower layer can penetrate the liner by osmosis, keeping the paint moist and workable, for several days if required.
They can be purchased from artists supply stores, but I made myself a small one using s small, flat food storage container (with a lid), a half of a kitchen sponge and a small piece of silicone baking paper… Total cost, about $3.00. This is sufficient to keep small amounts of Vallejo acrylics usable for up to a week - 10 days. It’s invaluable when your painting time is short or rife with interruptions or distractions.
I’d love to see a picture of one of these - could you post one!
Hi Rich,
Nothing could be simpler:
1: Plastic container with lid (this is a small one, about an inch and a half deep from a “dollar store” type place)
2: Half a kitchen sponge
3: a small sheet of silicone baking paper
The sponge goes into box, water goes on the sponge and paper goes on sponge, paint goes on paper.
You can buy a ready made commercial one from $12.00 up or make one from stuff you’ve got lying around at home. If you have to buy the bits, it shouldn’t cost more than about $3.00 (maybe $2.00 more if you have to buy a roll of baking paper).
Phil - thanks for posting that. My wet palette may be the best thing since sliced bread.
Note the plastic container can be sealed shut so the paint should be usable when you return to your work (depending on time lapse).
I don’t know if it matters but I used distilled water in mine. I was told I should use DW to thin my Vallejo paints so I figured it couldn’t hurt.
Also, mine uses parchement paper ( I don’t know if this is the same as silicone baking paper).
I’ve also heard you can use multiple layers of paper towel, cut to shape/size. You just saturate the paper towel and Bob’s your uncle.
I’ll check out the success of mine once I get back to my model on the weekend.
Thanks for posting the pics!
Thanks, Phil - this could be one of the most useful additions to my kit.
Cheers, Rick
2 wize guy remarks for ha ha?
I think I just wet my palette
Wet pallets don’t burn as well at the bush party!
Sorry had to tho’
