So being new to airbrushing, I’m still in the process of buying my stuff, and I’ve been reading up on airbrushing and tools and accessories. Im yet to actually use one. And one thing that jumped out at me which I haven’t considered before - is “needing” an airbrushing spray booth…
I plan on doing little 1/72nd scale airplane models to get back into the swing of things, before moving back onto 1/48 and then 1/32, am I really going to need one?
Ok, I have never used one, however, I do plan to build one for my new work area. I use lacquers, enamels, and acrylics, and figure in the long run it would be a good idea.
I think it really depends on the kind of paint you plan on using. I use Tamiya acrylics for the most part and the odour is pretty miminal. As well, I use a double action (Iwata Revolution) and there is very little overspray. In fact, all my airbrushing is done at my model desk. I just use a piece of blank paper under the part I’m airbrushing and it’s more than enough to protect my desk.
I will also keep a window open and have a fan on. (I model in the basement).
I think if you will be using a single action then there will be a lot more overspray.
I also only use acrylics but I do have a spray booth. Also use a respirator. While we’re on the subject, safety glasses too.
Do I “need” it? I don’t know. Someone smarter than me will have to answer that. I don’t want to find out the hard way. The stuff wasn’t expensive and the PPE is surprisingly comfortable.
I’ve used one for years. Very convienient, vents out of my garage window. No need for cardboard or newspaper is a big plus. I still manage to get crap in my paint on occasion but helps with the fumes. I dont think you need one but it sure is handy. You can paint day and night in any weather, but consider humidity.
This raises a good point - where I am in Townsville, summers get really hot and humid. The model room has aircon and so on, so I can run it on the “dry” function, but - what do I need to keep in mind on those especially humid summer days?
You need to tell us more about your working area. Do you live in an apartment where others may smell paint and thinner? Do you work in basement, where you only need to keep wife or other family members happy? If you work in a garage, not much of a problem depending on which paints you use.
In high humidity lacquers do present a problem. Acrylics and enamels are not as bad, depending on what you thin them with (I know folks who use lacquer thinner on them- does create a problem).
The work area will just be the 4th room of a 4 bedroom free standing house which is currently a disused guest room, turned into a hobby room. So it’ll just be me and the wife sniffing up all the fumes
My house is very dry in the winter and dry (flash off) times pick up substantially in the dry air if the house is well up to temp. I’ve noticed with acrylics now that humidity has picked up some and the heat basically not running in the day, that they are slow to flash off or slower to flash off. So I use a hair dryer between coats which picks the flash off right up.
Don’t try to spray lacquer in humid weather it will blush. And actually, if you have a hobby room as you mentioned and it’s within your normal living area ( apartment or house) then the spray booth becomes more of a concern if you use solvent based paints in general. Back in the 1950’s and 60’s, we or at least I, thought nothing of spraying them even in my bedroom but lets just say as a society we have come to know better now lol. Don’t try to spray lacquers and enamels at your work station and not vent it outdoors somehow is my suggestion… Today there are many options from portable, even folding paint booths, if the room is dedicated to hobby use, in due time consider a booth for it. Now with acrylics and painting small parts you can find me spraying those into the kitchen trash can as well as using the booth. But not lacquer or enamel.
Enamel is especially forgiving about not blushing in humid weather by the way. But really when it gets like that I’m generally not painting anyway, I switch to tying flies in the best air conditioned room in the house for our annual trip to Maine in the fall salmon fishing.
It’s not just the fumes… you are putting very fine (wet) dust particles in the air, some of which will dry & go further than you imagine, which your lungs cannot easily get rid of.
If for no other reason, a spray booth (lots of recipes using squirrel fans & furnace filters online) will get this paint/dust moving away from you/your household/pets & into a trap.
If you build one with a front door/flap, you will now also have somewhere to put your freshly painted models.
You’re outside aren’t you? You’re spraying in open air. I spray in my garage with garage door open (no spary booth) during summer months as long it’s not humid out. There’s are no standard size spray booth for 1/48 scale and 1/35 scale model kits.
The only time I spray outside is when I’m using a rattle can on top of a cardboard box. Afterwards, I immediately bring it in the garage to dry.
