Some more progress to post about today, normally I also get some time in on Friday nights but since yesterday was my birthday, I was a little “distracted” shall we say. Picking up from last weekend’s update, I did some more browsing of reference photos and decided that the prototype photo that didn’t have the sliding portion of the air intake was in the minority, so I went ahead and added the slide along with the tiny locking wing nut. Looking at those same photos, I noticed that the reflectors weren’t present so those were removed and the points where they were glued carefully sanded down to remove the marks left behind. The presence of the extra raised screen on the intake seems to be a 50-50 proposition though…so I still kept that one off.
I also noticed that back in Step 5 I had missed the installation of parts F50/51 which are additional side supports for the fighting compartment. These are shown already installed in place in that step and have number call-outs but I overlooked it since it’s the step that installs the fenders and the rear hull plate.
Steps 13 and 14 deal with the assembly and installation of the various tools and gear on the fenders and includes overhead diagrams showing the layouts for both the left and right sides. I removed all the tools from the sprues and cleaned them up but will not install them until after I’ve painted the exterior and before the fighting compartment sides are installed. The tools all require PE straps to be added, that will be done after they are painted as well. The tools are all “standard” Pz38t tools but the layout for the pick and shovel in particular are where the biggest changes are. The shovel blade is too thick to fit where intended against the rear hull side, so it was sanded down considerably to thin it out and get it down to the right size. Curiously the fender layout on the left side overlooks the large crowbar, part K1, but in Step 15 it’s shown as already installed, so you have to be watching or you’ll miss it.
I also constructed all of the spare track runs using the provided Magic track links. One run of 7 for the hull nose, one run of 2 for the right rear fender, one run of 5 for the right front fender, and one run of 4 for the rear fighting compartment exterior. The end links were drilled out using a #74 bit in a pin vise to simulate the missing pins and open holes on those links. Some of the links had raised ejector marks that required clean-up while others didn’t, so not too much work required there.
One of the biggest let-downs for me in the tools department was the jack block. This one comes off the B sprue and while the instruction diagram shows it as nicely detailed with raised bolt detail for the binding straps, the actual part looks nothing like that. With the exception of the small wing-nut in the center, the part is devoid of any detail. I added the missing bolt heads using the leftover K18 bolt heads and created some wood grain pattern using the tip of a #11 blade and a magnifier.
Rounding things out for these steps was the assembly and installation of the jack and the front Notek light. The jack assembled without any issues but I had a major problem with the kit-provided PE retaining straps. The bend lines are extremely fragile and once bent, don’t tolerate much movement/handling before coming apart. I found this out the hard way with the first strap while attempting to fit/adjust it…it fragmented into 3 different pieces while test fitting, so I had to scrounge replacements from my PE spares bin. These were added to the PE bases using CA gel and then bent to shape to secure the jack in place.
The Notek light base was installed first to the fender bracket using Gator Grip glue. Then the base of the Notek was added with the same glue, carefully positioning it in the correct forward position. Once dry, the hood/lamp portion was added using liquid glue to complete the assembly.
I stopped work here because the next sections are the fighting compartment sides and I wanted plenty of time to work with them in individual sessions, so that will be on the agenda for tomorrow’s efforts.
Total Session Time: 4.75 hours
Total Time to Date: 19.5 hours
