I like this one. MM, might I suggest a more realistic backdrop for photographing it? I haven’t looked at the link for more photos, so I may be speaking out of line. But shooting it in front a poster of a wintery scene would really bring out the artistry in this one.
Several things jump out here and a little research goes a long way.
First the trees have all this greenery under the snow but have the shape of a deciduous tree. The Ardennes offensive wa in late December. The only foliage left on trees at that time are browned out oak leaves.
Secondly, you have a guy about to fire a Panzerfaust, the range of which is 30 meters, under a hundred feet. No one seems to be takkng any cover, including the officer in the Nashorn, who looks pretty darn casual.
Further, the backblast will cook the two guys on the berm.
I have to agree with AJ about the trees. The forests in the Ardennes were mostly coniferous and managed. The trees were replanted at the same time and at set intervals. Along the pasture edges there would be different types of trees, and the spacing would not be uniform with the excepting of wind rows. Many of these trees in the pastures would be deciduous types but there wasn’t any evergreen deciduous trees there. As AJ noted about the oaks is correct, just a few leaves would be left on the tress at this time of year.
A common practice of the German infantry was to wear the white side of the camoflage uniform out and the upper portion be the camoflage pattern. This was so that when they walked through the trees their lower torsos would blend into the white snow and their upper torsos with the trees.
That nagged a bit–along with the fellow standing up aiming his StGw-44 (which looks very much like he is shooting “over” the 12’-15’ tall trees. But, at that level of pickiness, that looks like a PzF 60. However, with all of this weapon pointing going on, where’s the rest of the Nashorn crew? Nobody is running to disengage the travel lock?
Ok, so it would have been better with some 6-7" evergreens; still a good dio for the effort, though. The snow is not overdone, and there’s good visual balance without any clutter.
it appears the stage is set but the actors are out of sequence.unless this is panzerfaust practice that guy ready to fire must see something no one else does.and yes where the heck is the rest of the nashorn crew.and unless they have been in this position for some time and snow has fallen,i see no tracks behind the vehicle.i do like the winter scene.the vehicle looks good.and i like the general idea .
Many thanks for your kind comments and compliments! Aj is right about the leaves which should be brown, not green and about the shape too. detailfreak is right about the track traces, and I myself had noticed the unlocked position of the gun. All these things will be passed on to “Art Instructor” - the modeler - for future improvement.
BTW, I’ve changed the name of this dio to “Battle of Stalingrad” because someone on another site told me that the real Nashorn “Puma” actually fought in Russia, here’s the real pic :
I love it, I really like the backround color of the cardboad, most of us use bright colors like blue, yellow, orange, red and green etc. White good too espesally with your diorama, it make a appearance of a thick winter fog coming in, very realistique.
Now that my photos works, I can send some great one like that. Good work!
Many thanks for your kind comments, T-rex! I used white towel as ground and white T-shirt as background so as to make the dio blend with the winter environment. As for summer dio. I used to use blue as background, but recently changed to black. It would be great if I have some pictures or paintings to be used as backdrop, but I don’t have any.
BTW, I forgot to answer MadMel’s question about the snow. “Art Instructor” used fine salt and sodium bicarbonate to simulate it.
I really like it overall. One thing I may add is that if you look at the third photo from the top, it looks like the track of vehicle is floating off the ground.
Many thanks for your kind comments, m1garand! You’re right about the third pic.
aj, there’re lot of pictures on the Net but I think very few has enough resolution to be printed out big and still look good. At least the size I need is A3.
T-rex, yes we’re talking about pictures that can be used as background or backdrop.
Well i think any one who can produce a dio to this standard is ok in my book. I think it looks great. If i could make just one critisism’ette i would ask where are the shells in the back of the tank? Not a lot of point having it on the frontline without ammo lol.
