Difference between wash and pigment powder
Hi,
I am a little confused as to the difference of effect between pigment powders and washes, esp. When ppl mix the pigments with some liquid - effectively creating paint…
Would love to hear your thoughts on how they differ.
Hi Redra washes can be with pigments if they are very wet (thinned with water and a drop of dish washing liquid) or the same with chalk.
A wash is basicly a thin paint. Pigment by itself can be applied to get a similar effect. Washes can also be applied as a pin wash, to nestle into panel lines without staining the surrounding surface, which is difficult with dry pigments.
Both produce a semi-transparent affect, like a stain. If you are very good with an airbrush you can get the same effect with it. So there are at least three methods of replicating stains- probably more. Dot filters do pretty much the same thing.
Paint washes are stronger when handeld.The others are mostly wax based.
