Detailing Masts
Hi again,
Perhaps this could go under techniques, but since it applies to ships, I have asked here. How do all detail your masts on sailing ships? Are they all hust a uniform color? Do you create texture? How?
Since to masts are made of wood on the real ships, you would possibly see knots, grains, etc. Since the masts on my Santa Maria are smooth, I am wondering if it is possible or necessary to try to create a wood look on them. Any thoughts?
Robert
As usual in any Santa Maria project, we know so little about the real thing that it’s impossible to give definitive answers. My guess is that the Spanish shipbuilders made masts and yards out of single trees whenever they could - and in those days big trees were much more common than they are now. I have a vague recollection that the old Revell Santa Maria depicted the main yard as being made from two pieces of wood overlapping and lashed together in the middle, but I have no idea how Heller handled it.
I also don’t know what sort of finish or preservatives the Spanish may have used at that time. In later periods there are references to “blackening the yards” - probably with some substance containing tar and/or lampblack. But what, if anything, was used for that purpose in 1492 is anybody’s guess.
You’ve had impressive success at giving the “wood grain” impression on the hull. Something similar would be appropriate for the masts and yards. Here’s a trick you might try. Start by painting the entire spar with a good, even coat of beige or light brown. Let that dry thoroughly. Then take a bottle of dark brown and dig a dollup of thick, gooey pigment out of the bottom. Put a good-sized drop of that substance on one end of the spar and let it dry for a minute or so. Then sploosh one of your fingers in it and run the finger down the length of the spar, leaving a fairly straight but irregular pattern of the dark brown behind. With a little practice you can do a remarkably convincing immitation of wood grain that way.
The Pamir, of course, is another story entirely. Most of her spars were made out of steel, and painted.
Bob
Try this I normally turn my mast out of wood when possible.But when using the kit mast I use a 50 or 80 grit sandpaper really coarse.I sand it down especially removing those fake wooldings.Don’t smooth it down with the finer sandpaper you have now created a kind of wood grain.I paint or stain the color I want than after that dries I’ll put awash of eiter black or burnt umber on it. If it needs it I’ll dry brush on a lighter color.For wooldings I take the model rope and hold one end down where you removed the molded woolding. I wrap the rope around that end several times. I have the other end of the rope eyed through a small needle. I push the needle back under the wrapped rope opposite direction from the end your holding under your finger.Once you have the needle through pull both ends of the rope at the same time. This tighten’s it put a drop of glue to hold it cut the excess off both ends and your done.This is harder to write how to do it than it really is to do.
Rod
