HEY ALL OUT THERE QUICK QESTION I HAVE DECALS THAT ARE YELLOWISH AROUNF\D THE EDGES WHAT DO I NEED TO DO KEEP THAT FROM HAPPENING AND HOW CAN I GET RID OF IT PLEASE HELP
[edit: When I moved this to the decaling forum, I modified the title. --dvoss]
Place the decal sheet on a window pane, facing sunshine, and the yellowish thing will disappear. Make sure there’s no condensation on the window!
To keep that from happening, it is a good idea to keep decals of kits you purchase into zip-lock kind of bags.
And, by the way, can you try to use ‘normal’ letters instead of capitals? It’s so much easier to read…! Thanks!
Domi
thanks that helps me before i apply them but what about if its yellow on the model
Deano,
Once the yellowed decals are on the model, I’m not sure that problem can be overcome.
Anyone have a fix for that?
Use the tip of placening the decals for a week or so taped to a window facing the sun, or if you have a steady hand, use a new no.11 blade and trim away the clear carrier from the edges of each decal - but it’s hard to do for things like stencilling.
If it’s yellow on the model, you might have to live with it…
Cheers, Tree
