Decal Solution Question
I used a decal solution set from Testors on my F-16. I was not really impressed with the product. My decals would not settle in the grooves of the plane. I was wondering what I should use next time to give me the best results. - Thanks
I use Microsol and Microset and haven’t had any trouble other than it fogs Future if it’s put on too soon after painting.
Same here. The Micro Sol/Set combo works well with most all modern decals.
Testors Model Master brand has two kinds of decal solutions, one is a decal solution for general surfaces (#2146) and the other is a decal solvent (#2145) for complex surfaces. I use them both and have never had a problem. I take it you used thier solution for general surfaces then you need to get the one for complex surfaces as this one will set decals on grooved or raised surfaces
Hope this helps.
Air Master
Microsol/set never lets me down
Thad
