See the attached pics and you’ll see what I’m referencing when I state decal residue. Is there something I need to do prior to the gloss coat which is to follow? I sprayed a gloss coat prior to applying these. I’m using Micro Set/Sol. I’m sure you’ve seen my posts on it from yesterday. Thanks all, Ted.
Yes,I try to gently clean off any water or decal solution stains with a moistened Q tip
Yes! But be very careful to not loosen the decals.
Most of that should disappear under the next clear coat.
I should say gently around the decals
