De-fogging canopy
I oversprayed my Blue Amgels F/A-18 with Krylon acrylic crystal clear coat. Great glossy finish but undortunately, the canopy is somewhat clouded now. Any way to restore the clarity? Thanx.
There are 2 things you can try.
One is to polish the canopy with gradual grades of of sanding sticks. Starting with a grade of 600 working your way up to 1200 or higher until it gets the shine you like.
Two is a simpiler method that may work. Just dip the canopy in future. Set it on a paper towel and let it set for a day. If the canopy is attached to the plane you can use this method as well by applying the future with a brush in small even coats.
Good luck and hope this helps
Paul
Thanx Warlock, I’ll give it a shot.
fogged canopy from varnish?
Just give it a good shot with Future or buff it with polish cream and then Future.
no problem redbird let us know how it turns out.
Paul
Yes, I might say that I’m a pro on fogged windows. Thats is, in making them, not specifically restoring them.
I don’t know how I do it, but I 've messed up quite some canopies. That has given me the opportunity to restore some as well.
Sanding with a high numbre grid is the first answer (try your local auto shop foor 2000 grid sanding paper, or perhaps higher)
I’ve got some Tamiya polishing paste. works ok
Toothpaste might do the trick as well. In the Netherlands we’ve got a brand that is reknown for its horrible effect on the teeth, because of the sanding effect. Bad for the teeth, means that it is good for restoring your canopy. It’s the next step when having sanded with the aforementioned sanding paper.
Normal/decent toothpaste doesn’t sand enough. It’s just too sofisticated (it really is), and not harmfull enough. You can keep that toothpaste for it’s normal apllication purpose.
Best of luck!
(another option is to buy a new model, and replace the kitpart, or to ask the manufacturer a replacement part. Give it a shot!)
Profile
