I’ve recently started my first build involving some serious styrene surgery (whoops, alliteration! ), and I was wondering what the experts say about cutting up models.
The build in question is Tamiya’s 1/35 IS-3. I’ve purchased the relevant Aber D-25t variant for it, the relevant Friulmodel set for it, and Eduard’s IS-3 Fenders and Toolboxes set.
The Eduard set in particular is looking a bit scary. As I’m sure most of you know, all IS-3s except for the extreme early production models had toolboxes in the hull. The Eduard set updates the Tamiya IS-3 to include these. This involves cutting out most of the sides of the hull. Any tips on cutting styrene?
Drill a whole bunch of holes slightly inside the cut out lines, all the way around. Cut out from one to the next, and I’m speaking of 1/16" holes with less than that in between, with the tip of a knife or a tiny saw. Use files to get to the final opening size.
One trick I like is to mask around the area to be kept, then paint the scrap side a distinct color, like black on tan plastic or white on green plastic. When you are filing out the opening, file to remove white.
Regular sewing thread can be used as a “saw” as well.
Doesn’t really fit all applications…such as the situation GM posted. I use it regularly to cut control surfaces free on aircraft. Take a 15" or so length, tie a small thumb loop at one end, wrap loop around thumb…3-4" later, wrap the rest around your index finger…just work it back and forth (it helps a LOT to first scribe the line to be cut). The friction of the thread on the plastic will cut it (technically, the friction builds heat and the thread melts its way through). It does leave a rough edge that will need to be cleaned up, but does not remove as much plastic as a razor saw.
For removing a whole section, as in the ship, or removing a section of an airplane fuselage, a razor saw is a quick method of cutting. The original razor saw was the Zona, a one piece unit of blade and handle, but there are several now, including an X-acto saw blade for use with the larger handle, so you can replace the blade when the teeth are worn.
A tip on using the razor saws with plastic. They heat the plastic when sawing, so it gums up and gets hard to work. Water periodically dripped on the blade helps cool the plastic at the cutting line, and makes the cut easier.
Don’t try to take that side off in one piece. I would make a series of saw cuts perpendicular to the edge of the part, to within about 1/32" of the long cut. Maybe about 1" apart. Scribe the long cut first with a knife or razor blade or scribing tool, again about 1/32" in from the edge of the area to be removed, and snap the pieces off. Finish with sanding stick and file.
Also get an understanding of how the brass part attaches. Does it overlay the cut area, in which case you can leave an edge under? Or does it have to fit in flush.
razor saws work well for longer straight cuts only. If it is a short cut not at top or bottom of a panel it does not work, nor does it work for curved cuts. For those I have to revert to the series of holes.
I’m using a combination of the holes and the string, and it’s working well. There’s some fit issues, but it’s my first big photoetch set, so I’ll take whatever comes.
Well, it seems I removed some stuff I wasn’t supposed to and I could use some tips on how to scratchbuild with sheet styrene. Do your tips differ? The pieces I’ll have to scratchbuild are really simple. Basically a two-dimensional trapezoid, with three sides 90 degree angles, and the fourth side about a 40 degree angle.
For simple staight cuts in a sheet of styrene stock, if it is thicker than about 30 mil, the scribe method works (similar to cutting glass). Scribe a straight line across the piece with a #11 blade, then bend at line over table edge- the piece will break at the line. You may get a somewhat nicer break if you scribe two lines, one on each side. However, for that to work the two lines must register almost exactly.
0.30 mm or 30 mm? The styrene that I bought is 0.75 mm or 0.030" thick. Scribing sounds good, and I’ll try it. I have plenty of the stuff anyway, and mistakes won’t be really costly.
You are getting the picture, bud. The sheet you have is what Don is referring to. You’ll be whipping out constructions soon. Another good tool I like for these kinds of projects is a Northwest Shortline “Chopper”.
It’s great for mass production of same sized parts.
Well, I think that’s really the last thing I wanted advice on. Thanks to everybody for responding, even through my incessant and sometimes obvious questions
