Where do you order decal paper, and what software should i use?
www.Micromark.com has some, I would recommend the white and not the clear. If you use inkjet, you need a spary which makes sure the ink doesn’t run when you wet it. Testors also sells a "kit’ with paper, spray, and software. But you can really use any software that lets you resize a picture and print it out. (word, photoshop, paint, etc…)
thanks
