Currently on the Work bench
Just finished some missiles for a 1:48 scale F-15 I am working on…
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5176.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5177.jpg)
And here is the F-15 to date…
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5178.jpg)
Also working on a 1:48 scale B-25…
!(http://i249.photobucket.com/albums/gg222/wed192/B-25 mitchell/100_5169.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/B-25 mitchell/100_5174.jpg)
and whipped this out tonight…
other models currently on my work bench
SU-34 1:72 (95% complete)
SU-24 1:72 (90% complete)
A-10 1:48 (90% complete)
F-16XL 1:32 (5% complete)
HO-229 1:48 (45% complete)
F-111 1:48 (45% complete)
F-105G 1:48 (10% complete)
F-4D 1:48 (5% complete)
F-14D 1:48 (15% complete)
XB-35 1:72 (45% complete)
The Pro-Modeleer B-25 is very tail heavy! I have had to completely fill the nose wheel well as well as behind the instrument panel and yet I still have to add a lot more (see last picture) to barley sit on it’s nose wheel!
!(http://i249.photobucket.com/albums/gg222/wed192/B-25 mitchell/100_5399.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/B-25 mitchell/100_5400.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/B-25 mitchell/100_5405.jpg)
Those missiles look fantastic! Please eleborate on your method and what brand they are. Painting and attaching weapons really is one of my weak points - i can never get them to look any good. How did you do the rings of colour? Is is masking and paint, or did the set come with decals?
The rest of your builds look great - you appear to be building faster than I could buy, well done. Please keep the WIP updates coming.
Chris.
The missiles came with the 1:48 scale F-15 kit I am working on. There is no magic to the finish on the missiles. I hand painted them (GASP!) then picked up after market decals for the missiles. Some of the decals were a PITA (pain in the …) to put on, discovered that it is easier to cut up the decals to smaller manageable sizes. Then I put on a coat of Testors dull coat for a rattle can. I just have 5 more missiles to go now.
Nice work so far. Hope the B-25 nose gear holds up to all that weight.
Regards, Rick
At this rate it will either be bow-legged or a low rider when finished…
Had thesame problem with my kit but closed her up before realizing it…DUH! I used the rear hatch/step stool method to keep mine sitting level! Make sure you put that puppy in the middle of the shelf!!
stuffed the engine nacelles last night and the sucker still sat on its tail. I was afraid that the weights, once put inside the nacelles would shirt the center of gravity to far back again. The sole reason for this is I want to do the glass nose version not the painted nose version. If I did the painted nose this would be a mute point. I was hoping (and still am) I could get away with the rear entry hatch as a brace.
Was warm enough to get to the paint booth today…
Got started on a 1:48 HE-111
also chipped and dull coated my KI-46 heavy fighter (it’s now ready for weathering)
!(http://i249.photobucket.com/albums/gg222/wed192/play money models/jap heavy fighter/100_5654.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/play money models/jap heavy fighter/100_5655.jpg)
also camo-ed the F-15
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5650.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5651.jpg)
Then redid the camo in my F-111
!(http://i249.photobucket.com/albums/gg222/wed192/My F-111/100_5652.jpg)
http://i249.photobucket.com/albums/gg222/wed192/My%20F-111/100_5653.jpg![](http://i249.photobucket.com/albums/gg222/wed192/My F-111/100_5653.jpg)
and finished the camo on my Stuka as well
!(http://i249.photobucket.com/albums/gg222/wed192/JU-87B-2 Stuka/100_5657.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/JU-87B-2 Stuka/100_5658.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/JU-87B-2 Stuka/100_5659.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/JU-87B-2 Stuka/100_5660.jpg)
Also got the base alum on my AR-234 and XB-35 I need to touch up on those two and will be posting them tomorrow…
Whoa WedFactory, slow down!!! You’re making me feel inadequate! I can only concentrate on one build at a time. I’m still finishing off my first build for the year.
Is that the 1/48 Academy RAAF F-111? I’ve got it in my stash, but not game enough to start, I took one look at the wing mechanism and decided it will have to wait until I’ve got a few more builds under my belt.
Please keep the WIP posts coming!
Chris.
Yes it is the Academy kit, but it is the Libya raider version. ( wanted this version because my Dad was USAF and we were stationed in England for 3 years at RAF Bentwaters a near by base)The wing mechanism was very easy to build. One catch I found out after closing up the wings. The kit as 6 hard points on the swing wings, and so does the real aircraft, but the outside hard points don’t swivel with the wing and can only be used with the wings swept full forward. If you plan to model with swept wings cut off the 2 outside hard points and fill the holes.
Today:
  1. Painted the bottom of my F-111 (now gloss coating for decals)
  2. Painted the yellow nose and wingtips on my Stuka (now gloss coating for decals)
  3. Weathered and am dull coating the model
  4. painted the missiles for my F-15
  5. masked and painted the F-15
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5680.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5681.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5687.jpg)
I used spray can for the white…
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_5671.jpg)
Wonderful stuf!! dries to touch in 15 minutes, goes on in thin coats. I put 2 coats on the F-15 in 20 minutes (took me longer to mask it!) and from start of first coat of paint to pulling masks 1 hour. It is a gloss paint, dries very smooth. I definitely am going to use in on my XB-70’s.
Sorry about the quality of the pictures, the gloss white plays “L” with the auto exposure on the camera.
This is were I am going with this kit…
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_4384.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/F-15 Eagle/100_4385.jpg)
Well now have the F-11 decaled and added the engine exhaust and landing gear, It now looks like an airplane…
!(http://i249.photobucket.com/albums/gg222/wed192/My F-111/100_5718.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/My F-111/100_5717.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/My F-111/100_5716.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/My F-111/100_5719.jpg)
Well I finally got the decals on the Stuka, took 3 days! (took over 20 minutes each to soak the large crosses on the underside of the wings to break them free of the backer paper!)
!(http://i249.photobucket.com/albums/gg222/wed192/JU-87B-2 Stuka/100_5721.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/JU-87B-2 Stuka/100_5722.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/JU-87B-2 Stuka/100_5723.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/JU-87B-2 Stuka/100_5724.jpg)
have some touch up painting to do and add the fiddlely bits before its ready for panel line highlights and weathering.
I found a way to do panel lines on raised panel lines modes on another forum using pastels and thought you guys would like to see it.
The A-10 I am finishing turns out to be a great testbed for this technique. At this point the model is painted, decaled, and dull coated. The dull coat is important as the pastels do not stick to gloss coat. The dull coat rougher texture allows the pastels to grab better.
For this technique you will need chalk pastels, a small paint brush and a large paint brush…(in the photo below I have ground some black and med gray pastels for use…
!(http://i249.photobucket.com/albums/gg222/wed192/My A-10/100_5770.jpg)
Using the small brush, brush the black pastels on the model following the panel lines…(try to center the brush over the panel lines)
!(http://i249.photobucket.com/albums/gg222/wed192/My A-10/100_5766.jpg)
Don’t panic it looks heavy right now but the next step tones it down. After applying the black pastel, use the large brush and the med gray pastels and lightly dust the entire model. With aircraft brush the direction of air flow, on other models in the direction of the most likely weathering.
!(http://i249.photobucket.com/albums/gg222/wed192/My A-10/100_5769.jpg)
I have moved on a little further…
!(http://i249.photobucket.com/albums/gg222/wed192/My A-10/100_5768.jpg)
!(http://i249.photobucket.com/albums/gg222/wed192/My A-10/100_5771.jpg)
I will post pictures when fully complete…
(might even use this on my stuka…:hmmm:)
I have next Spitfire on my workbench - this time Airfix Mk II 1/48 - from 303 Sqn. Code letters and serial numbers painted with masks.
Quite easy job except awful decals (roundels and fin-flash)
WIP
Enjoy!
