First time poster long time lurker so go easy on me. I have made a couple of models before and am slowly picking up my array of tricks and skills yet am no where near good. These are a couple of them: and http://i.imgur.com/2uh4s.jpg Well, I have a couple of questions for you in that case. Here goes.
I am working on the Timaya M2 Bradley Tank (well just starting) and feel a bit scared to get into it. What I want to do is create a texture on it before I get too far into it and realize I did not do enough. I must point out that I do not own an airbrush and realize this may be a big problem. I am not against buying one in the least bit, I just do not have the finances at the moment to pursue this as of yet. I have a few ideas as of right now and would like your criticisms and input as to how these work. Of course I will still being doing them on scrap plastic to see how they work (for science!) and for my future knowledge. Here are my ideas:
a) Spray a thick coat of primer and sprinkle sand. If the sand sticks to the primer, spray another coat and let dry then follow up with my final spray color.
b) Use spray glue and stick the sand on that way. From there, spray a coat of primer to ensure my final coat sticks to the model.
Of course I don’t know if either of these are going to work but what is the harm in experimenting. I also have another question. How important is primer? I just use it because of my background in carpentry and painting walls but I don’t actually know how well it works or if it does things in certain situations so I am looking for some information on that.
To end off I will try to put what I am saying in a simple a way as possible as this may be a bit confusing.
I am trying to create a texture as if someone was on an assembly line trying to push out as many tanks as possible in a short time with little care for blotching or clumpy paint. I have heard of using talcam powder but I think that was only with an airbrush. Thank you for your help in advance
sand will be WAY out of scale. subtlety is key. actually, try srpaying a coat of spray adhesive on a spare piece of plastic. That just might do the trick, but it can splatter. test it first. there are a lot of methods: EXPERIMENT! EXPERIMENT EXPERIMENT! you’ll know when it look right.
EDIT: ah! where are my manners? Welcome to the forum! Nice looking AT-AT!
The texture your looking for I believe is created by a dremel tool. There was a recent Sherman build I believe that showed this. I wish I can find it. It creates a rough almost rust like finish but painted.
Will just spray adhesive work on its own to create “some” sort of texture? I will of course test it first, don’t want to screw it up before I even start the project. Thank you for your quick response.
Thanks for your response as well, how do you think it will work on the whole model with the dremel trick. I will try to look this up as well but the article would help greatly. Also, I don’t know if you saw or don’t know the answer to the primer question. I am planning to repaint my whole model green. Is this too big of a task?
This is not exactly what I am looking for but looks extremely interesting and I can most likely use this elsewhere. What I am looking for is paint texture on the outside of a tank, sortof like a non-smooth finish yet everywhere so it seems natural. Thank you for your information though, I definitely see myself using something similar to this in the future.
It sounds like you are talking about giving the metal a cast look. Don’t do that to the paint, do it to the plastic.
There are many ways to do this. Coat the plastic with liquid glue to soften the surface and dab it something like a Scotch-Brite pad or a stiff paint brush. Dilute putty with lacquer thinner or nail polisher remove with acetone and dab it the same way as the before. Both of these methods usually benefit from take a bit of what glue or thinner you used and lightly brush over the surface so it’s not to spiky looking.
This was done with Squadron green putty and nail polish remover
For a Bradley, you want to add ant-slip coating as I outline in the Armorama link above. A Bradley (not a tank by the way, but an Armored Personnel Carrier, or APC) does not have a rough cast hull. It is all smooth plate, aluminum alloy armor. Here is how the terra cotta spray looks on a Bradley.
