Corvette in 1/72: Revell v. Matchbox. Advice?
I have a choice between these two, but not sure what the differences are or which is a better build. Also, for added detail, am I better off with the Revell Platinum kit with it’s wood deck and 1 sheet of P-E, or should I opt for an after mkt P-E set that seems to provide a lot more pieces. It wont be RC motorized, nor will I be reshaping pieces for 100% accuracy.
This is for a commish build, so the client will pay the costs, I’ll just pay with my sanity. (to be honest, I wont likely use all the P-E, just the obvious and essential ones.)
I need advice ASAP. Thx
Read this:
http://www.britmodeller.com/forums/index.php?/topic/234936238-revell-172-flower-class-corvette-platinum-edition/
Based on that, I’d go for the newer offering.
Hmmm;
I have the older Matchbox offering with it being fully R/Cd . It has flaws , Yes .But with judicious planning and a good eye she is an attractive little ship that can be operated in real world wind and water , waves and wakes shedding out of her freeing ports like they are supposed too .
Some off scale adjustments had to be made to get scale performance ( like an oversize rudder and prop . ) Everything else is O.O.B. and if done right , tough as nails so far . She’s now four years old and has cruised in the Susuin straight , the Sacramento river and the lakes and bays of the Guadelupe and Comal rivers here in Texas .
She has weathered well with all her paint being Humbrol ( when you could get it as easily as Testors ) . The only thing new is the turned gun barrels and the real metal Depth charges . I did the top hamper and radar cage in brass when I built her .The two life rafts are cotton netting with real painted cork for the float areas .
With her Battery ( a 12 volt Motorcycle battery , This one is number two ) and an all electronic speed control with a four Channel Futaba radio . She is a jewel to run and seems very much at home in water. Now as a Static kit she is and can be impressive O.O.B. or Build it like this must be your most detailed ever ship model .She will be beautiful both ways . T.B.
I built the old Matchbox kit and converted it to RC almnost 30 years ago. I used a scale size prop and the scale rudder, and had no issues with running it that way. IMHO, you don’t need an overscale rudder-- if you’re concerned about the turning diameter, you can go with greater than scale deflection.
I think the Flower is the perfect plastic model for RC conversion. It is big and beamy, with a displacement of about 5.5 pounds, and looks great on the water, even “rough” seas!
I saw the contents of the new Revell Platinum edition just last week-- ti was nicer than I was expecting. The wood decks are not those over-thick plywood things–it is a sheet of real wood veneer with adhesive backign that is abotu the the thickness of a vinyl sticker. I found it interesting that Revell repeats the Matchbox error by providing the wood veneer for nearly the entire model, when the real FLowers only had a small amount of wood decking. (The guy who was building it was only using it on the foc’sle bridge, and are by the K guns.)
I was also impressed by the nice metal barrels that the Platinum kit includes. plus the nice PE set.
Bottom line: If I was to buy a model today, I still don’t think the Platinum kit is worth it, unless I was doing a diplac model. For an RC project, the old kit would be good enough.
I’d get the brand new 1/144th Revell of Germany offering…
Did that. Love that scale. Shapeways is making all kinds of little sets of sailors.
Underneath all the extras in the Revell kit, the plastic is the same. The Revell kit is a rebox of the Matchbox, plus all the add-on goodies. It comes down to whether there’s a significant difference in the price.
