I am working on a Revell Corporal Missile & Transporter kit, and thanks to the good offices of a fellow on another rmessage board, I was able to get in touch with Mr. Dale Hardy of the R.G. LeTourneau Heritage Center. The Center owns an early-Sixties Transporter/Erector, currently resting peacefully on the grounds of a private collector in California.
My question was about the model’s rather bare-looking driver’s compartment. Mr. Hardy was able to supply pages from the Technical Manuals for both early- and late-production machines, and, thanks to the California collector, was able to send me photos of the Heritage Center machine’s driver and assistant driver compartments.
These pictures seem to me to be valuable enough that, although I don’t normally post here, I thought they should be shared with military modellers who might be planning to build the Revell kit.
Mr. Hardy’s latest email to me contained information about the peculiarities of the Heritage Center machine, so, with his permission, here is that email, slightly edited:
“I’ll explain the differences you see. The vertical posts you see [rust-colored, protruding from the “cargo” area] were added by the previous owner. You will notice that the circular grapples that would grab the missile are not there either. The previous owner purchased this machine to use for setting tall poles at a ski resort. He removed the grapples and welded in cross braces to mount the vertical posts you see. He would evidently strap the poles into the cradle the posts made and lift them to vertical. His son said he either didn’t finish or he finished and it didn’t work like he wanted so he never really used it. He just parked it.
“The “ducts” you see on the bottom of the front end are actually head light sockets. As these machines were built, modifications and changes were made. [Mr. LeTourneau was fond of tinkering with designs in mid-stream.] This is one of the changes. The Revell models were made from a mid to late 1950’s version. The one we have in California is an early 1960’s version. On the Revell models the headlights are on top of the hood.
“There is a book you should get that gives a lot of details on this machine and others built by LeTourneau during that time. The book is “R.G. LeTourneau Heavy Equipment – The Electric Drive Era 1953-1970” by Eric Orlemann. You can find this book on eBay and other internet sites. It is a companion book to “R.G. LeTourneau Heavy Equipment – The Mechanical Drive Era 1921-1953” by Eric Orlemann. The book shows the evolution of this machine with three versions. The third version is the one the Revell model was made from. You have to remember the Revell model was first introduced in 1959 so the changes we have on ours in Placerville had not taken place yet.
“These machines also had RC. That’s not Radio Controlled, but Remote Controlled. There was a remote control box with a heavy wire that could be attached to the rear of the machine so the operator could see how to better and more accurately set the missile down onto the launch pad.
“I’ve attached [five] pictures I received from my friend in California that show the inside of the cabs. The right side cab had no operator controls. It had only a bar to hold on to. In the left cab the potentiometer is located under the right side of the operator’s panel.
“There was a small fire extinguisher to the left of the panel post, [and] a fuel primer handle mounted on the post. That box or drawer to the right of the seat is not part of the cab. I think it just got stuck in there. I’ve talked to my friend that worked on these in Germany and we feel the two bottles behind the seat in the right side cab were added later and not original equipment. They appear to be pressure bottles for a fire control system.”
In a later email, Mr. Hardy also said, “…You mentioned that the operator’s panel may have had a decal in the original model. I have an original 1959 model that has the original decal sheet and instructions and there is not a decal nor does the instructions call for one. This is true for the 1983 History Makers model also, no operator’s panel decal.
"The other item is the crank-like handle that is included with the model to go in the right-side cab. The instructions list this as the Steering Handle. I don’t believe this should be put in. My guess is that the model designer didn’t know how this machine could be steered without some sort of a mechanical steering device. He didn’t know it was steered electrically with a toggle switch so he installed a ‘Steering Handle’.”
Here is a link to a Photobucket album containing the pictures Mr Hardy sent me (plus two of the Heritage Center’s machine I found on the Internet as part of a description of a tour of the private collection)—click on the thumbnail:
http://s193.photobucket.com/albums/z256/hilbyf/Corporal%20missile%20transporter-erector/
