I read that you can use cork board for diarama bases. So if I wanted to build a diarama with a crater hole would I just take about 6 pieces of cork board and cut a hole in each one then stack them? I’m not sure if that is how that works. Also how do you make grass for the diarama. Just one last question, is it better if you want to make a model barn with balsa wood or just by a plastic barn? The scale of my diarama is 1:35 and the size of the grass I want would be like if you didn’t mow a yard in a long time like two weaks. So it would be around the middle of the tow on a 1:35 scale soldier.
personally i wouldnt go with the cork board idea 4 a crater hole ide go with styrafoam and 4 grass theres static grass u can buy at any hobby store how tall of grass do u need? ur last question personally if ur good with balsa wood thats the way ide go but u can find some realy nice kits wat scale is ur diorama?
I have used cork board as a base, but I covered it with pieces of pressed board, and small pieces of plastic. The problem with the cork is that if you don’t seal it somehow, cement and silicone will “evaporate” in the little spaces. Cork works ok as a working base, but I would agree that it probably is not the best material to build with.
MF
