Convert 1/48 UH-1D to UH-1N
Hi all
Is is possible to convert an Italeri 1/48 UH-1D to a ‘N’?
I can only get hold of D models and can’t find or locate the N version that Italeri made.
I know CC make an update set for the N version but does someboday make a conversion to an N?
Alternatively does anyone else product a 1/48 UH-1N kit?
Thanks
Don’t know of any conversion sets, but it can be converted. I converted a Revell 1/32 from a D to an N model some time ago. I carved a new nose blank and the new engine cowl blank and Vac-formed new N model pieces from them. It wasn’t too difficult. Here is the end result:
More here: http://www.hkngallery.org.uk/hkngallery.nsf/9e7858703c56bfb280256b960044cd7b/edf6eb2769f1c30180256f180082b23e!OpenDocument
Good luck.
Check Heller for UH-1N kit, it’s the same as Italeri’s
Thanks guys
Hi osjohnm,
Granddadjohn is right: maybe you’ll have more luck in finding the Heller Kit.
Some years ago (in the days before the 1:48 UH1N kits) there was a Cutting Edge 1:48 UH1N conversion set, consisting of a resin engine housing, resin upper nose and vacform lower nose. I did two of those that turned out OK but I don’t know if the sets are still available.
Good luck!
Gertjan
What those guys said. The nose is longer and sleeker with smaller chin windows, the engine housing completely different and the rotors have a shorter chord. Keep checking the hobby shows and e-bay.
