Guys,
Would the difference between 1/8th HP and 1/6th HP be significant as far as performance for a dedicated models only compressor?
Thanks for opinions.
Guys,
I doubt it. Such compressors can go up all the way to 100-150 psi, while you would only need no more than 30 psi.
I don’t think we’re talking about the same thing. The Paashe D500SR I looked at only goes up to 40psi.
My Porter Cable goes up to 150 but that is for woodworking with a 6 gallon tank, and a different beast than the Paashe and very loud.
Horsepower vs pressure depends on flow rate. The more flow at any pressure, the more horsepower required. Most airbrushes have a pretty low max flow rate, so airbrush compressors do not need a lot of power.
Further, one way to reduce power needed is to reduce leakage. Wrapping threaded connections with teflon thread aided the pressure I can achieve with my pretty wimpy Iwata compressor.
