Completing a really old, messed up, 1/72 Piper L-4 Grasshopper . . .
Hi all,
Back when I was a junior in high school, so '89 or '90, I went through mail order to get a Meikraft Models 1/72 Piper L-4.
The box
I got a nice letter from John Meikraft, though.
Nice letter.
I had built a bunch of models up to that time and felt pretty good about my skills, but I was not ready for a short run kit. I started working on it, using tube glue and brush painting. I even used a bit of filler putty. But, the fit isn’t great, the molding isn’t great either, and I had no idea up to that point that tube glue could make a real mess of cockpit plastic.
This is what it looked like when I put it away 34 years ago:
Another view:
My goal is not to make this perfect, but I think with my current skill and much better tools, I can make it good.
I worked on polishing and cleaning up the “glass” and fuselage.
And then masked and painted the light grey that will be the underside color, but used it as a primer for the whole thing.
After letting that cure for a day or two, I sprayed the drab green. My spray can is actually pretty old, and I got some texture from the can that I don’t like. I’m going to put a coat of Future floor polish on it, however, and I’m hoping the gloss coat smooths things out a bit. I really don’t want to strip the paint.
Here’s the underside:
Another view.
So it is not perfectly covered. I will do a bit of touch up soon. I may decant some of the spray paint and very carefully touch up the leading edge. Or I may simply leave it alone and start with the decals.
Nevertheless, I think this model will turn out well – at least when viewed at arms’ length.
Howdy Drew!
It sure looks better than before! Good luck with your build and have a nice day!
Paweł
Lewisburg?! I was born in Lewisburg.
Wow, Lufbery , you must have a great nostalgic attachment to this kit! [:P]
Very cool you still have that letter. Wonder if that guy is still around and you could send him a response with photo of the completed kit !
Thanks! I’m looking forward to getting decals on it.
Cool! Did you go to school there? It would be funny if we were classmates.
Nostalgia about sums it up. I was actully considering tossing it, but then looked at it and saw it wasn’t too bad. I figured i could finish it to look okay (if not great), and I’m glad I’m working on it.
I actually looked to see if Meikraft Models was still in business. I think they are. From what I could gather, they started business in 1987, which was just a year or two before I sent away for this kit.
