Hi:
This could be posted in Painting too, but because of the uses I will take you through, it is posted here. COMET, that ubitiqious Home cleaning powder. It’s been around for a long time. Many uses have popped up for it. But silently it crept into the tool boxes of Modelers. Why? Well, it’s versatile, easy to use, and as rubbing compound, polishing compound and Just plain usable for a lot, it solves spending a little to accomplish a lot.
Like most home cleansers it is mildly abrasive. It’s supposed to be, to scrub the bathroom equipment, kitchen sinks etc. Some modelers in a moment of unknown group think, started to use it to take out heavy scratches in Planes and Cars. Again, Why? Well, it’s a great intermediate polishing compound both dry and wet, or close to a thick muddy soup! It works well, gently, on paint too!
I also found, in working with Lexan, Polycarbonate sheet and Plexi, it is a perfect polish for those things that need to be clear! Styrene, A Breeze! I have more than once used it in the polishing regime for damaged Canopies and Windshields! Works great. Here’s a for instance! I had a 1/24 Airfix Kit of a WW-2 Fighter. The canopy somehow got gouged on top rubbing against the box, I guess.
I sanded it down and wondered after the body shop 600 grit could I get it finer, because sanding marks were visible in some places. Well, I resanded wet, and then used a mud on my fingertips of Comet, rubbing continously with those fingertips till it started to dry.Then I noticed the Canopy was Blemish Free, Well, enough that clear Gloss or Future finished it out and totally restored the clarity!
At that time no one had the inkling that the higher grits, 800, 1200, 1600, etc could be used here. I guess we all thought it would be still too coarse. Wrong! But even with that, Comet is a mainstay in my tool area. It is absolutely the best for adding to the scrb water instead of Dawn to get bubble free cleaning of the parts Before the application of Glues or Paint! NOTE!! For Safety DO NOT Add to water with Dawn in it! The Fumes generated will make you sick. Comet is to be used by ITSELF!!
