cockpit harness
I’ve been searching the forum site for info on how to make cockpit harness’/seatbelts from masking tape, any ideas on where to look for a how to article or can someone explain it for me. Thanks
icit
I do it one of two ways. Sometimes I double it over, creasing along the centerline, then cut to width. I do that mostly in larger scale, like 1:32. For smaller scale I often just cut a stripe out of the tape (tape pressed against a cutting mat. The single layer then has adhesive back to stick it to seat. For small scale I use PE fittings. For 1:32 I often bend fine craft wire into fittings.
Also, for 1:32 (the double layer method) I run the strip through the buckle and double back upon itself to create the “adjustable” section. For the smaller scale I usually dispense with the adjustment piece.
Masking tape has a color very close to one of the colors of the old military belts.
Thanks Don, I’ve been playing with that very idea and getting some very good results. I wish I could afford to build in the 1/32 range but the truth is I just dont have the space for it.
icit
Yeah, I have cut way back on 1:32. Current 1:32 project (using masking tape belts, too) is a racer (Laird-Turner) so it is pretty small for a 1:32. It isn’t scratchbuilt (except for interior- I trashed the whole kit interior and did it myself). In general though I am moving towards smaller scale.
I use the tape method all the time and really like it. Here is a tip, the tape takes paint very well. I paint mine Testors wodd and then dry brush with a light sand or tan. Works fo rme.
Brent
