Clear overcoat on die-cast model
When I,m not modeling, I buy die-cast scale autos. I’ve collected quite a number of 1/18 racing autos. Since I move quite a lot some of the models are damaged especially the paint. Scratches and chipped paints are common. I hate to see the detailed Tampo printed graphics chip away. I’m thinking of giving the rest of the models gloss clear overcoat. is it ok? I like to hear you advice. TQ
If you use Testors clear, I see no reason why that wouldn’t work.
Lee
I think you can better use Tamiya clear coat instead of testors gloss coat.
If you use testors gloss the cars will come out darker.
http://users.skynet.be/mbie
Regards
Eric
The problem is Tamiya is laquer, and can react to some types of paint, Testors won’t unless the paint is water base, which on a diecast probably isn’t the case.
Lee
I never has got problems with Tamiya clear coat.
I sprayed it over every type of paint. Also restored Diecast models with it.
Regards
Eric [:D]
Thank you guys for responding. Really appreciate it.
