Can you help me please? I have stockpiled a large number of early bird kits (ie Bristol Boxkite, Bleriot etc) and also a number of WWI types. I’m looking for the best paint to represent clear doped linin. I have used Humbrol #74 but it seems way too yellow!
Can you suggest anything? Ilive in the UK but should be able to get most brands.
I’ve never tried it myself, but I have a friend who used to build armor dioramas, and when he needed to represent something that was cloth he would use tissue sprayed with diluted white glue to cover the area. I suspect that it was the wrapping-type tissue and not facial tissue. Once the glue dries it can be painted any color you want. Probably a bit of work for a biplane wing, but it might give you some very realistic-looking results.
I picked up some Polly Scale “doped linen,” and it is VERY green. I used it for the sidewalls in this cockpit. For the exterior, I mixed Model Master “wood” and “flat white.” I probably could have gone lighter, but I think its better than the Polly Scale.
Given that there are no color photos and any samples of early aircraft have aged 80+ years, I’d feel free to go with either the Humbrol or the Polly S, which I used on a Fokker Dr1 and was given good remarks on the color.
