Cleaning Dusty Models
Hi all, can you guys give me some options on cleaning models? Pretty dusty and some are caked with dust. Thanks.
Heh. I consider it weathering LOL. I used to go at 'em with a nice soft paintbrush, but it’d be the better part of 3-4 hours to do them all. Then of course there’s the shelves themselves you end up dusting.
My solution has been to implement an ounce of prevention. I got tired of dusting so I began to invest in display cases I could seal up against the dust. Been able to find both my big ones on Craigslist for a good price. Had them 5-6 years. No more dusting.
Chris
The best cure is prevention. Keep 'em cased.
But…if they’re clearcoated, then I use a very soft brush and warm water…careful…careful…
Q-Tips help. The main thing is…go slowly…and carefully. It works for me.
Go to the drug store and buy makeup application brushes, the brushes are very soft and get all the dust off. Also compressed air cans for cleaning computers. If you have a compressor for your air brush you can use short burst of air to get the dust off. A car detailing brush also works well. Swiffer sweeper rags and their duster work well too. Remember to vacuum frequently and change your air conditioner filter every other month at a minimum.
I just very carefully run a yellow duster over the models, I literally let the weight of the duster clean the dust off it is quick, however it can break small antennas etc… As I don’t think I have a single model without a missing part somewhere lol.
I’d add that Tamiya sells a really nice static free brush for exactly this purpose. It has a large, very soft brush on one end; and smaller “detail” brush on the other.
I find it very useful and it sees a lot of use. Of course, being Tamiya it’s probably a bit over priced.
I use an airbrush with no paint or thinner, just the air flow. For really stuck on dust, I gently brush area with a soft natural fiber paint brush and then immediately blow with the airbrush. The flow from my airbrush at 15 psi is gentle enough I can even dust my planes that have a lot of rigging, WW1 subjects.
Don beat me to it. I use my airbrush, too, on a very low setting, and a soft paintbrush.
I used to use a brush that was made for dusting camera lenses. It was REALLY soft and had a squeeze bulb built into it. I still use the brush but the rubber squeeze bulb is cracked with age (like me) so I use my airbrush with low pressure at the same time.
Jim [cptn]
Thanks to all for the responses. Casing right now is not an option so I will try the methods mentioned.
Some timeless advice here.
Good recommendations here but this one is best, if you can.
