Laquer thinner will get rid of that dried paint in no time.
Putting parts in the oven is only asking for trouble as this might affect the part’s heat temper or could actually distort them. if hot enough for long enough.
Cheers !!!
I agree with the others, soak it in some lacquer thinner and if that doesn’t work then spend another $3 and get a new one. It is not worth the trouble for such an inexpensive part. [;)]
Well I am not sure which one fixed it, I had another thread with the same issue. In that one it was suggested that I put the parts in nailpolish remover.
I had let it sit in the Simple green over night, and saw no results. I then cleaned everything up and then let the two parts sit in the nailpolish remover. This morning, I checked and the paint was loosened up and/ or desolved.
I think I will give the thing a shot tonight and see how it works [:D]
