Cleaning acrylics from paintbrushes and airbrushes
I’m totally new to this and have been reading and watching videos to try to get up to speed. I plan on using Tamiya acrylics for both airbrushing and paintbrushing, and using the Tamiya x20-a for thinning the paint, but I’d like to use something cheaper for cleaning. It looks like either isopropyly alcohol or Windex with ammonia are cheap and will work for cleaning. Is there an advantage to using one over the other? Will they both work for both types of brushes?
I use Tamiya brand cleaner and Testors Universal Brand airbrush cleaner to clean my airbrush and brushes. Some folks here do use Windex and other alternative products as well.
I use the Medea-Iwata Cleaner for cleaning brushes and airbrush for acrylics.It’s fairly cheap at about $10 a pint,goes a long way.
I use laquer thinner and windex for my airbrush and General Pencil Company Inc., The Masters Brush Cleaner & Preserver for brushes after rinsing with water if acrylic, lacquer thinner if enamel or oil. Alwaus use the soap. It does so good at cleaning and treats the brush and conditions it. here is a link. They make other sizes too.
https://www.amazon.com/General-Pencil-Company-Masters-Preserver/dp/B001TNR7VM
Two part anser for you questions:
  1. Alcohol vs. windex as an airbrush cleaner for Tamiya acryics–I don’t know which is cheaper, but windex does a better job of cleaning an airbrush than does alcohol. The windex dissolves the tamiya acrylic, while the alcohol is just a diluent.
For other brands of acrylic, windex does not work as well. For example, I’ve tested the cleaning power of windex of tamiya vs vallejo acrylics. Windex clearly dissolves the Tamiya paint much faster than vallejo.
  1. Don’t use solvents to clean your regular brushes. Just use soap and water. The trick to keeping your brushes clean is to never let paint dry on them. Regularly swish your brushes in water while you are painting. Then when you are done, clean with soap and water. I also like the Master brush cleaner that someone else mentioned.
If you do allow a little paint to dry on the brush, you can try a cleaner like Winsor and Newton brush restorer. But don’t soak the brush in a solvent overnight because the bristles will come loose (I had this happen once).
Thanks, your explanation of dissolving vs diluting helps me understand.
I paint with Vallejo acrylics.
Having recently made a trip to Coast Airbrush for parts and speaking with one of the reps there regarding airbrush cleaning, I was told to never use Windex in an airbrush. The ammonia will react with the chrome lining inside the cup. Therefore, when I clean mine, I use either the Iwata Airbrush cleaner if I’m going for a quick flush, or I use 91% isopropyl alcohol for a deeper clean, and then allowing all the parts to air dry before continuing.
I also use Tamiya acrylics now and then. I highly recommend that you use the Tamiya thinner for your paint thinning. I have found that they do not hand brush very well but Vallejo Model Color does hand brush well. I just got some Vallejo Air to try out in the air brush thinned with their brand thinner and performed well.
I use lacquer thinner to clean both air and hand brushes. The LT removes both enamels and acrylics from both hand and air brushes.
Before anyone says that LT is too harsh, I have been using LT since the mid 1970’s and still have my first ab, a Badger 150 purchased in the mid 1970’s and still works like new.
My hand brushes last me an eternity. I gently tap the bristles inside the glass jar with LT and you can see all the paint come off that regular thinner failed to remove. I then gently wipe them on a paper towel.
Never soak the back end of an ab (where the trigger and air valve are at) in any kind of solvent. I have also heard not to use ammonia in a chrome ab cause it may etch and eat into the finish.
I use Gunze Lacquer paint’s thinner for cleaning airbrush and paint brush. And do not have any problem so far.
For brushes i use good old tap water. For my airbrush i have just started useing the same one as Tojo.
2nd plastic junkie on laquer thinner for both. I have been using LT for 20 plus years for cleaning both and still have my original airbrush that works great. I have brushes that are 5 years old and still work great.
Honestly, I always use the cleaner within the brand of paint I’m using. If I’m using Tamiya paints, I’ll use the Tamiya airbrush cleaner. A bottle of airbrush cleaner will last me years, so any savings would be pennies, if that. And, there is no question that it’ll work on the paint I’m using. My advice is to keep it simple
