Cleaning Acrylics from Airbrush Using Ultrasonic Cleaner
Hello,
I have an ultrasonic cleaner for jewelry which I use for my airbrush. I would fill the tub with soap and water to clean it but the process doesn’t seem to work wonders. I airbrush acrylics (Vallejo and Tamiya). I did some research on the best solutions for cleaning airbrushes and these were the suggestions from online:
  • 100% Ethanol
  • Rubbing Alcohol
  • Ammonia Free Windex
  • Vallejo Thinner
  • Tamiya Thinner
I have only tested with rubbing alcohol and will try some others soon, but what do you guys think? Is there a better solution to water and soap for cleaning acrylics from an airbrush?
Thank you,
Niko
Alcohol is flammable and the ultrasonic cleaner heats up. Don’t use it! Use soapy water. Dish soap 2-3 drops and water.
I don’t do a full tear down on my brushes often but when I do I just soak everything overnight in lacquer thinner. But I don’t use a US cleaner. Everything come loose or is even gone in the morning. I find if I really flush well immediately after spraying I can hold off a tear down for two to three months. Just on double action brushes back off the needle chuck and slip the needle back off it’s seat a liitle is all or it may stick, regardless how well it was flushed.
I doubt many US cleaners would be rated for use with alcohol or lacquer thinner but then I don’t know a lot about electric powered ones. The solvent ones we had at work were air operated though.
A caution against using an ammonia soak, in an ultrasonic cleaner or not. Ammonia will affect brass. Even a scratch in the chrome plating will expose the underlying metal. A soak in ammonia will lead to corrosion of the base metal.
A quick spray of ammonia, a dip, or a wipe with a soaked Q-tip is ok. It’s the soak that is the killer.
It depends on which alcohol.
Methanol certainly is quite volatile and burns with a clear flame that can be dangerous. On the other hand, isopropyl is quite safe in the reasonable concentrations. Don’t know about the 97%, but the lower percent stuff is pretty safe.
Late last night I did a full tear down and cleaning with 70% Isopropyl and it came really clean.
My trigger action though seems a little stiff, is it safe to put some Remington oil to lube the trigger action?
The sliding action for paint flow ? Maybe you just have the return spring set a little too tight.
For lube I use glycerin if anything at all.
I also use an ultrasonic cleaner on my airbrushes.
I use a jewelry cleaning powder that came with one of my ultrasonic cleaners. I’m not sure this is the exact product I use, but it is the same idea and this is where I will probably go to buy when I run out.
FWIW, as long as I clean the airbrush immediately at the end of a session, I don’t really use the ultrasonic cleaner that much. But it can help with stuck on messes.
Thanks for the tips everyone! I took a look at ultrasonic powders online and the key ingredient in most is potassium peroxymonosulfate, a powerful oxidizer used in pools. The ultrasonic powders are essentially non-chorine shock for pools packaged in smaller containers at a higher price.
Next time I clean the airbrush with the ultrasonic cleaner, I will try the non-chlorine shock.
That’s interesting.
