Canopy painting B-25 Mitchel
Thanks for your suggestions, now i have a new problem, i’m currently building a B-25 Mitchel, as you can imagination there’s a lot of canopy work, i just unmasked them only to discover paint bleed through, do you know of any special tools to use to remove the bleed spots?
I’ve just used a toothpick to try and clean up.
Thanks, I’ll give it a go.
If you used acrylic paints, a toothpick is your best bet. Solvent based paints tend to bite in and react with the plastic. Not too many, if any solutions at all for fixing that.
In the future shoot a layer of some kind of clear first then your base color. If you do this the only bleed through you should get is clear.
Thanks for the tip, toothpick did work however it left the canopies a bit battered, smudge and smeared, any thoughts on cleaning that up, glass cleaner?,
I’ve found touching up with a little acrylic clear like future floor wax can help a bit.
I have small cotton swabs, pointed , hard … tamiya sells them. I find they clean up the messy edges quite well , and a I have a lot of messy edges :grinning_face_with_smiling_eyes: They also seem to leave the glass clean
I usually use a toothpick and with an x-acto blade cut it to a blunt wedge and work at the paint to remove it.
Patience is a virtue and pays of well.
As stated above, toothpick and scrape the paint. I’ve tried with “some” key word is “some” success using Isopropyl Alcohol and using a superfine micro paint brush to rub the paint off.
