Canopy masking liquid
Dose Anybody use it and what brand would you recommend ?
Thanks.
I have used Micro Mask and it works ok. Starts out as a blue thick glue like liquid, dries clear. Have not tried any other brands.
I use Liquid Masking Film made by Bob Dively Model Aircraft Inc. It is white almost like elmers glue and dries clear. It works really well and comes off easily
Thanks for the info guys.
bigfoot,
Do you know where has it in stock ? Ebay charges big money for shipping this little 16oz stuff.
Vallejo do a liquid masking film which is ok to use with spraying acrylics, if that’s easier to find.
I’ve also use ordinary waterproof Elmers’/PVA instead.
the Micro Mask is available from Microscale
www.microscale.com/products.htm
they still release new decal sheets, also, although many people think they are closed
cnq, Towerhobbies.com is where I got it. I made the mistake of buying the 32 oz and it goes a loooooong way. I would have been fine with the small bottle. If it sits to long it does get a film on top, but it peels off and is fine underneath. I just have more than I will probably use for the rest of my life LOL:)
I’ve read that you can mix dish detergent and white glue to make your own. Not sure of the exact recipe tho.
I avoid using liquid mask now. Have had severe problems removing several different kinds.
cs.finescale.com/…/139078.aspx
check out this thread.
As stated, i’d ditch any liquid masking and stick with tape.
If you do want a liquid mask, I’ve found the best one is the Humbrol Maskol (purple colour).
The blue Mr Mask is terrible and can react with future type products to cause fogging.
