Just got back into modeling not too long ago after 15 years. Just tried my hand at dipping a spare canopy in Future as an experiment and it came out okay, but left a distortion where it collected along the frame and would not run off. Some questions…
Should the canopy be prepped before Future (like Polly prep) especially after polishing with tooth paste or something? If so, prepped with what?
Do you clear coat with Future before or after painting frames? Or both?
Already learned about not creating bubbles in the Future before dipping. How do you get all the Future to run out of a bubble canopy without distorting it or causing bubbles?
What do you mask a canopy with to paint the frames? In the past I’ve used Bare Metal Foil as it renders a ridgeless result, fits into the finest recessess and can be easily trimed. BUT it leaves glue behind that is a real bear to clean up. Also bought Micro Mask but it seems to me the resulting line will be no different and as imperfect as painting the frame with a brush.
You’re description of how you’re using Future on canopies leaves out a rather important step. Once you’ve coated the canopy tip it so the corner of one edge is down and then touch that corner to a papertowel or soft cloth to wick that last droplet off the edge. Then while it’s curing you must keep the canopy under cover (I use a small Glad disposible bowl and lid) so that dust particles don’t collect on the surface as it dries (at least 24 hours).
I don’t prep the surface in any way and get great results.
Goo gone will remove masking residues if they occur, however I use aluminum monokote trim that adheres well but doesn’t leave a residue behind. It’s also much cheaper than say Bare Metal Foil.
Wow, excellent point, didn’t think about dust and my bench is in my garage. Got lucky this time. Will definitely do the papertowel and cover procedures.
Hmmm, “aluminum monokote trim”…you got me there. Is that a tape, self-adhesive foil or what? Is there a brand name product of said stuff? And should I use Bare Metal the Goo gone doesn’t mar the future finish?
Also, do you use Future before or after painting frames? Or both?
Really appreciate the pointers, I’ve long lived past the point of wishing to learn everything for myself which means, by definition, mistake!
I usually use either Tamiya yellow tape or parafilm for my masking. I used to use BMF, for the same reasons you do. But, removing the adhesive residue w/o damaging a delicate paint job could be troublesome. One thing that I found to help was to seal in the paint with a good clearcoat before removing the BMF, then remove the foil and just rub the glue residue continously with a Q-tip (with NOTHING on it) to gently buff it off. Works well, but w/o the clearcoat barrier the paint will prolly get rubbed off too. HTH! [tup]
Yeah, I got Tamiya yellow tape but it seems too thick so trimming it without hurting the canopy seems dicey.
What’s parafilm?
You know I just thought of another alternative. Gladd now makes a “sticky” saran-wrap product I used in cleaning up some tile this weekend. It adhered very well but has no actual adhesive on it. Not sure it’ll seal at the edge well enough to prevent paint seepage. Will experiment.
Parafilm is a thin wax-like product used in laboratories to seal test tubes. When stretched, it takes on a sticky personna that clings well to canopies, but doesn’t leave residue upon removal. Here’s a link to a tutorial on using it:
Sharp (new) scalpel blades are a must, but scotch tape is too sticky, and is likely to lift Future, even when cured. Tamiya tape is fine for canopy masking - it’s the same stuff that Eduard use for their canopy mask sets, after all - just use a No.10 blade in a rocking motion to trim it to length. Also more damage-resistant than Parafilm.
