well i am at that piont to attach the canopie to my ah-6j little bird. i have futured and painted it . now my next problem is will crazy glue frost the canopie even after i have futured it. this is the first time i hae done this producer and it turned out pretty darn good[:D][:D]
future will usually prevent that, but you can just use white PVA glue (Elmers) and not worry about it.
You can also use one of the NON-FOGGING CA glues, there are literally dozens of different CA formulas out there each producing slightly different results.
Ga -
I’ve been using white (Elmer’s) glue for capopies for years and never have to worry about it. As I don’t “play” with my models ;), bullet-proof adhesion isn’t required. Has the added bonus of drying clear and having “filler” properties.
Archer out.
