Can you paint over a clear coat?
I clear coated prior to decal application. As I was nearing the end of the decals I realized I forgot to hand paint some small details. Despite the fact the model has been sprayed with Tamiya clear coat, can’t I go back and paint those small details I left out? Then spray a top coat of clear before starting my weathering.
It shouldn’t be an issue. I’ve done the same in the past.
Shouldn’t be an issue. Clear coat is actually just another coat of paint.
Only problem I can see, as long as you’re using compatible products (acrylic vs. enamel vs. lacquer etc), is if your clearcoat is very glossy, you might have a hard time with paint coverage.
But that should be easy enough to overcome with a satin or matte coat as needed, even if brush-applied just over the details to be painted.
Do it all the time over lacquer clear coat and paint using acrylics and enamels with no issue.
Yes,some actually use it a primer
