I have a couple of British tanks that I plant to build in North African schemes. With the sand/black/green combo, what color green is it? I was wondering if it was the same as the RAF dark green or was it the bronze green? I would assume that stocks of RAF green might be available to the tankers especially since the Desert Airforce wasn’t using it.
You were correct, there’s alot of information in those 3 files. I just wish there was more information out there on British vehicles. Osprey/Vanguard is the primary source. Luckily I have some old Armor Profiles on the Mk VI, Crusader and Valentine as well. Things you pick up as a kid and hold on to!
I think it would be fun to have a 1/35th scale of the Mk VIB for France 1940 and early North Africa projects.
If you can locate a copy (I found mine on E-Bay) of ARMOUR CAMOUFLAGE & MARKINGS NORTH AFRICA 1940-1943 by George R. Bradford ISBN 0 85368 101 5. It was originally published by Arms & Armour Press in 1974It has loads of great pictures and plenty of colour sketches of all armour types for the Allies and Axis forces in North Africa. There is even a section of colour swatches for each country. There are photos and colour sketches of captured vehicles in use by both sides as well. A great book to have in the reference section.
Check around, you’ll find a copy. I have since buying mine seen several copies at shows and on Ebay.
Hi Greg: I have that book too and it’s nice. However, be aware that a lot of info in Mike Starmer’s research (see the links above) contradicts Bradford’s work in the 70s. I think Starmer is the latest and most definitive. HTH
I am sure that some of the info is “corrected” over time and further study. It’s like opening the Zaloga argument “What Olive Drab is True Olive Drab?”.
I look at it from the stand point of:
A. If it looks like the reference photos when it’s finished great.
B. More importantly did I enjoy the build and further my interest in my hobby.
Mate, ukgeoff is all over it. Go to the MAFVA site & bookmark it. It has EVERYTHING you need to know about WW2 British camo - full stop. Not dissing gburdon’s response though; I’m sure that is a good source too.
