Thanks for the clairification Bish and I tend to agree with you for the most part. I also found that around Cyprus, Ciaro and the like (North Africa) they did indeed actually wear this uniform too, though not as much. I also agree with your beret assessment. A friend of mine on another European forum has a father who was in the 1st SAS and provided guidance for the soldiers uniforms. The uniforms I’m displaying in the build were worn from North Africa, through the Mediterranian, and Europe. On funny thing I noticied when researching the uniforms and gear was the French SAS units did not have the same uniform discipline as the English as thier berets were worn bent to both sides and even to the back, and the shash over either eye (not the left), even in the same formation. The same can be said for thier patches, tabs, and jump wings (varying greatly within the same unit), etc.
Moving on with the display base, after the Milliput dried I took a walk with the goal of finding small rocks and texture materials that look real. Often, when looking at the scale railroad stuff at the hobby stores I think much of it looks unrealistic. In their defense, there is some stuff that is absolutely wonderful, but for what I needed for a 1/18 base, real dirt and rock was a must. My walk brought me to the end of my driveway to scoop up some pulverized rock sitting in the gutter between the curb and my transition. Some quick sifting and this is my base material.
Before I lay the initial rock bedding I took the time to make a final walk through of where stuff will be going.
I purchased a neat looking SAS parachute pin to embed into the display base. Being a pin it has two needle points with clips to go through a lapel. I though I had two options, one was to drill two holes in the base to mount the pin and the other was to cut of the pin tips and use CA glue to mount the pin basically anywhere on the base, I chose the second option.
So here we go, taking the pin to the model cave in the basement, it fell out of my hands while going down the stairs and landed on the cement floor in an crack between the stairs and a stack of storage boxes CRAP! After 20 minutes of moving everything I finally located it and brought it to the work bench MOVING MORE CRAP. After cutting the pins off I began using my Dremel to remove the rest of the pin mount so it could fit flush. During that moment I was wearing safety glasses but somehow got a small piece of ground up brass in my eye CRAP, AND OUCH!. After fishing it out of my eye I finished the grinding. I then brought my CA glue and SAS pin upstairs to the display base. After applying the glue I found the location I wanted to put it. Only then did I notice that two of the colored insets on the wing were gone,…CRAP AGAIN!. They must have been knocked out when the pin fell from the top of the stairs to the cement floor. So now I have a pin that I can no longer use and CA glue on the display base. I was lucky enough to catch the problem and get the pin and glue removed before it cured or caused an ugly mark on the display. Overall, a lot of trouble for nothing.
Onward and upward, I laid out the screen rock along with some extra fine ballast over the rock onto the mat board. In the process I wanted to have the items I’m adding to the base appear as though they have been sitting for a few days with sand blowing around them. The way I accomplished that was to use the unpainted items to mold their own places. Prior to the gorilla glue setting, I removed the kit parts and cleaned them for painting.
When looking at many photos of North Africa I was surprised to see that other than mostly the deep Sahara or parts of Lybia, there is vegetation and even some grass or foilage in many if not most of the areas. To replicate that I used more scale train diorama supplies for burnt and green grass, dry (dead) vegetation, and some small half dead brush. Once that was set I began painting and adding the “stuff” to the base. Final painting and detailing was done while the items were on the base. The sand bags and tarps were painted in various shades of color starting with the darkest and finishing with the lightest shades. In between the applications I added washes to those items to show the shadows and variations and finished them with some dry brushing.
Once the base was complete I added the jeep and cut an antenna to fit in the display case. The only items I need to add to call it done are another SAS pin (on the way), expended brass casings, more decals (on the way), and some light pastel shading. I suppose I will show one more update once this is all done…
Here is the mostly completed display with the jeep.
Till then, be safe, happy, healthy, and have fun modelling something…
