Well, I’m back from vacation. I primed and did the faces on the figures. Not my best priming job, but the paint still had something to grab onto. The middle figure is from Dragon and I used a resin Hornet head in place of the very good Dragon head. The tankers were tweaked since they didn’t photograph well at all. The Infantry figures are done; I still need to add the rifle slings, and now onto the tank crew.
Excellent job on getting the drab colors to look damp and soaked and cold.
The figure maker for the one on the right has, for some reason fit the figure with a USMC P41 full transport pack (key visual clue beign the diagonal crossed straps from the suspenders)
The suspenders
You need the P41 suspenders to fit that pack as shown. The shoulder straps go to the back and cross diagonally. The “shoulder straps” run only through the rings and bac upon themselved. THis would require a huge amount of scrounging in ETO, and would be complicated further by the fact that the items were scarce enough in USMC service (and that USMC did not start fielding OD 782 gear until April of 1945, with 3MarDiv getting 1st dibs).
WHat the caster wanted to depict was the Army (War Department) M-1944 Field Pack system, which did not see deliveries into the field until early 1945 in ETO. And was supplanted in April-May 1945 by the M-1945 system, which simplified the straps & attachments.
'44 pack on the left–it has four attachment points for the secondary pack. It also needed the M-1944 suspenders
'45 pack on right. Which could be fit to either the '44 or the '45 suspenders.
THe '45 back & suspenders never really saw full Army-wide distribution until about 1947. The sudden need for web gear in 1950 saw abunch of '44 pattern gear suddenly “modified” to '45 pattern use (This makes collecting these items complicated)
M-1944 Suspenders
The straps on the '44 pack are very short as they only have to reach the loop on the suspenders above the “V” attachment, then doubling back on itself.
Hey Capn, thanks for the history lesson regarding the field packs. I finished the 3 tank crewmen and put them in the Sherman. Now on to the base. This site is acting up. So here are the pics.
Hey everyone, I started the base and it is drying down, so I can add the accessories. But I did start on one more figure to add to this diorama. It’s from Tamiya’s Infantry Assault kit except I substituted a Hornets head and instead of the M1 Thompson, I will give him the M3 Submachine gun (aka the Grease Gun). It’s a WIP.
Well I finally finished this last figure. I was happy with how he came out. The uniform decals were a bit of a hassle; since they were older Verlinden US WWII Uniform decals, but worth it as it gives the figure character.
I know the site has been going thru some problems. So I finally finished the diorama. The dragon teeth are after market but everything else on the base was scratchbuilt. As always all comments and critiques are greatly appreciated. Hopefully I’ll take some pics with background photos.
Well, I believe I found the best pictures for my background. I also found out that I’m in need of new ink cartridges for my printer. But these will suffice. I hope everyone likes the pictures and I can honestly say that this diorama is done.
Sorry for being late to this but now that the forum is back and I can log in, I can comment on it now. If it weren’t for the printer lines in the background that could dang near pass for real. The build is indeed up there with the best that I’ve seen…that much is for sure. The photography of it just puts it over the top.
