Anyone have any suggestions on where/how to get the blurry ground-effect to simulate flight? Like for a base, to place under an airplane on mounted on an acrylic rod. Ive looked around but haven’t found anything. Thanks!
Try these folks: https://www.coastalkits.co.uk/newstore/
Cool link, Fotofrank! Now I know where to get the hardstand and revetment walls for my F-4B project. Thanks!
That’s perfect, thank you!
I use Google Earth. I pick a location and download the image. I select the size of the image compatible with the altitude I want to depict.
A project coming up is for a plane from a Russian Aerobatic team performing at the Paris Air Show. I have alread downloaded the image. I glue the printouts to a nice wood base and then dullcoat the image. I drill the hole before gluing the image for the base, then cut the hole carefully with a scalpel.
I have previously done a USS Akron over Lakehurst, and a B-47 over Homestead.
