Ok, this may sound odd, but I can NOT find Blu Tack locally. I have checked EVERYWHERES. So I see some people using silly putty as a mask for hard lines, but I am curious if it would still work like Blu Tack would for holding card stock off the surface for soft edge camo jobs. I am not even sure of the ability to find silly putty locally, but I have a suspicion it will be infinately easier than finding Blu Tack.
Remember that “Blu-Tack” is a specific product made by Bostik. IF you ask for “Blu-Tack” by name and they don’t stock it, then that’s that.
What you want to look for, if Blu-Tack is unavailable, are the generic versions, which may be named “Power Tack”, “Poster tack”, “Poster putty” etc etc.
You should be able to find these or equivalent at any stationery store and “dollar store” type places.
The “Blu-Tac” or poster putty is available at most office supply stores as well as hardware and home centers…check the paint department or where the carry picture hanging supplies.
Silly Putty or a variation of it is available at most toy stores, craft stores or department stores that have kids toys. I found mine at Hobby Lobby and it came inside an egg…Big Putty! I was something like 89 cents on sale!
I would recommend Silly Putty, over Blu Tack any day. It has so many uses including masking off camo, such as masking off the teeth of a tread, to masking off pieces from mufflers to wheels for painting, the uses are almost endless. Just look at these pics:
BE CAREFUL with that “Blu Tack” stiff–I’ve heard several people report that the stuff stains or can discolor paint schemes, and leave some kind of residue that is a b*tch to get rid of.
I have had problems getting Silly Putty to stick and have been using blu-tack, handy-tack, UHU and others for ages. I use hadny tack the most since it is easily availabe at Bed, Bath and Beyond. Stay away from the stuff at Staples as it was very oily.
If it stains/discolors the base coat it is usually due to the paint not being fully cured. Any time that has happened to me the 1st gloss coat for decals evened everything out and it was invisible. The best way to get those little sticky bits is with a ball of the same stuff. just knead is a second or 2 to get some “fresh” stuff and press it on the stuck stuff a few times and it is gone.
Thanks for all the suggestions folks! I picked up some HandiTAK I found at Walgreens. It is yellow, but it appears to be along the same vein. I also found an interesting link to making your own silly putty from regular white glue (which I have tons of) an some liquid startch (I think my mother has some lying around somewheres in the laundry room) so I may try making a nice large batch…for free!!! Now thats economical! [:D]
I have used play dough once for masking. It works reasonably but playdough dries over time, so after a day or two it cracks, becomes brittle and shrinks. So it’s only useable if you paint inmidiatly.
I have used a cheap generic Blu Tack variant with no residue problems.
I use “blu-tak” or whatever the heck it’s called. Like Marc said, whenever some get stuck I just “blot” it up with some more. That usually works pretty well. I’ve found that the longer you leave the tak on, the more “boogers” you get. It’s good stuff though. I highly recommend it!
No I did not know about BluStik. I did pick up some of the generic stuff from Wal MArt. It is yellow, but is, I assume, the same general stuff. If the yellow stuff is a no-go then I now at least know to check Grainger (who my company does a fair amount of business with).
The same people (Bostik in UK) also make a ‘white-tac’ conveniately available in the 99c stores, which has less residual issues, so use, paint, & remove as soon as practical, I only use acrylics now, so haven’t had problems with enamel thinners turning it into ‘goo’
‘silly putty’ is all but unobtainable here, I found some in an egg, with silver flecks in it, but it dried out & was useless for masking.
I’ve used straight PVA (elmer’s) glue to mask wheels, etc, but now use white tac, unless my kids have nicked it for their HSM posters again!
