We had that stuff too. I’ll never forget the smell it had, pretty srong. It sort of makes you wonder how far away you could smell it per person and how long the odor lasted. You could also wonder if it had and detrimental side effects too, sort of like A.O. in a bottle.
It’s around 65% DEET at, IIRC, 10% (ordinary Off™ was like ±1%).
The smeel was the smeel [:)] Which would be hard to pick out among the LSA and the sort of sweat one generates with humping 20-30kg of ruck.
The very real issue was that there wa no sulfur nor Pemetrin in the mix to keep the parasitic arthropods at bay. So, while it would, theoretically, keep biting insects away, fleas, chiggers, ticks, et al, not so much.
But, it was cheap at the surplus stores, back in the day. And, if you could stand the stink of it, would keep flies, gnats, and other flying annoyances at bay. Whic hcould be a boon while hiking a trail that might bring a person through a cloud of such things.
Bug juice was also great for softening up the camo sticks so they didnt tear your skin off when you were applying the stuff to turn green… [aln] double points! Look like the local flora and keep off the local flying pests.
Stik, you are so correct. By the time I joined, they had switched to Cutters Insect repellant. The smell was a lot more pleasant. I used to pour some on my palm and then rub the camo stick in it to soften it up and then onto my face, ears and neck it went. (Avoiding the eyes). It was good as the base coat, then any fine tuning of the camo on your face and neck, you did afterwards.
BTW Pawel your helmet came out great, and your muddied up BDU’s look excellent.
I have shaded the jacket and glued it to the pants with 2-component epoxy:
I have also shaded one of the ammo pouches and the butt pack. I want to pick out the tapes lining the edges in slightly different colour. The other ammo pouch is still under construction as it is going to be shown open:
So that’s it for now - thanks for looking and have a nice day!
As you might note I’ve put the sling attachments on it and the sling is in the making, like you suggested. The hardest part to do is that spring clip on one end, but I’ve already have an idea for it, misusing some PE leftovers, so stay tuned…
Other thing I was working on is one of the ammo pouches modified to be open:
I’m also working on the remainder of the gear. I hope to be able to use the Easter break to wrap this up.
That models the “stiffness” of those posches very accurately. Even sopping wer they stayed pretty rigid.
The M-79 looks good.
The eyelets on the belt might want to be a tad darker. They were blackened brass. And the top surface would burnish to a color kind of like a metalic version of Radome Tan, if that gives an idea. So, not really a brass, nor agold, nor a silver.
Over that would then goe just and grime effects.
They get a unique “look” when “salty”
Versus new:
(Note the stenciling is on the inside of the belt.)
The fabric on those is very thin, so, they “smush” around contents kind of closely.
They will hang “lopsided” too, depending on hose the contents shift around.
For being of a not-thick fabric, they were/are sturdy and resisted tearing mostly (and were considered expendable if they did tear–only natural as they were menat as an expendable item in the first place).
Not quite as floppy as, say, a plastic grocery store bag, but not as “form-sturdy” as, say, a rucksack or pack.
I just couldn’t wait any longer - I’m calling this one done! Here are the pictures:
I’d especially like to thank Cap’n Mac for his support and the photos of real life gear. Thank you also all who have commented - you made this build much more enjoyable for me! Have a nice day and see you soon on the forums!
