I consider myself an old beginner with scale modeling and am now working on my 4th model in about as many months. It’s a 1:48 Tamiya Spitfire MkV. My first attempt at airbrushing camo and using photo-etch. Everything was going so well until it came to the decals…
Am I correct in my impression that Tamiya Decals are pretty crummy? They look like stickers with oversaturated colors and never seem to “melt” onto the paint no matter how much solvaset or micro-sol I apply.
As went to apply the top wing RAF Roundels, I noticed that the decal was semi-transparent and the camo pattern was visible through it. “That won’t do,” I says. Then I remembered the white backing decal sheet buried under the sprues in the kit box, slid the Roundel decals carefully off the wings and back onto the backing paper, applied the white backing to the wing, let it dry, applied setting solution, then again applied the roundels. Not only was a sliver of white visible around and underneath the insignia, but the double layer of decal looked like a peel and stick sticker at that point. Blimey!
Disgusted, I took tamiya masking tape to the offending concentric circles - we can’t defend the Isles looking like that! But, unfortunately, no matter how i poked and stripped at them with the tape, small pieces of decal would not yield to my fury.
Fortunately, I had laid a generous coat of Aquagloss before “the stickereing” and my paint job remains mostly unscathed after the incomplete removal.
My question is this… Assuming the flakes of decal are impervious to tape, windex, etc. Should I perhaps mask off the circle area, sand them away, repaint with the grey cammo color, and lay down those new ones I ordered from eBay? My other option would be to paint them on with stencils but I am not sure I really want to attempt that at my skill level… Do you think I’m on the right track here with my solution?
