According to military channel’s top ten,they say Challenger.I don’t know.I guess it’s subjective.I would say a toss up between Challenger and Abrams.Challenger better protection,but Abrams more speed ?
I would be hard pressed to pick between the Merkava Mk IV, Challenger II or the Abrams for the top spot because each has good marks in each of your criteria.
Worst modern tank? Gotta be the LeClerc. I heard it’s weapon system only fires two rounds before a white flag pops out of the commander’s cupola and the tank only runs in reverse… [:D]
While I’m biased, I’d say Abrams. Abrams is much faster, and if it hits you with a smoothbore round, you’re screwed. The challanger is slower, bigger, and in my opinion, more likely to break down. Plus as accurate as rifled rounds are, they are lower on the damage. Really, it’s a toss-up. now, if production is a factor, Abrams wins, hands down. Challanger would be facing over 20-1 odds. anyway… I’ll leave it to the experts to decide!
This topic comes up quite often and always ends up being a pissing contest of national pride for each of their own tanks.
Basically, all the contemporary NATO/Western tanks are pretty much equal to each other with minor differences between them since most were jointly developed or share parts. For example, the Abrams is pretty much equal to the British Chally 2, the Leo 2A6, the LeClerc, the STV 122, Italian Ariet, Israeli Merkava, etc. They all use pretty much the same components and systems.
The real factor that will make or break a tank is its crew. A well trained crew will beat a poorly trained crew in equal tanks any day.
By the way, there is no “h” in Abrams. It is named after GEN Creighton Abrams, a US Army tanker of WWII and Cold War fame.
Best modern tank kit is probably the Dragon M1A1 AIM and M1A2 SEP. Best European modern tank kit is probably Tamiya’s Leopard 2A6. Hobby Boss made an error on the suspension of the Merkava IV or else it would have been the best Asian modern tank kit.
I thought it was the Italian Ariete jobby that would only run in reverse? [;)]
Same old tub-thumping coming up? Yawn, [|-)]
Anyway it’s horses for courses, & who got to spend the pennies on the shiny things! of course, we are all objective scientists & engineers here aren’t we? [^o)] They are all designed to different criteria, according to what the respective design specs were.
Britian got Challenger1’s because a near-eastern country had a regime change & the Shir 1 design was adapted to the Cholly 1, (which as fielded in OP Telic, didn’t have adequate dust filters initially!). This led to the Challenger 1 & 2 earlier than otherwise planned.
Designed to field against the Russian T72/T80’s in Europe.
Its rifled 120mm can and did hit moving targets from a moving platform at up to a (verified!) 2 1/2 miles.
One broke down in GW1, & survived 120mm rounds at point-blank range to disable it.
The only combat loss in GW1
The US/German joint committee designed & then cancelled camel-pig MBT 70 led to the M1 Abrhams and the Leo series.
The US got the Abrams ( BRITISH CHOBHAM Armour, GERMAN Smoothbore 120mm), fast but needs to fuel every 4 hours.
Nick-named ‘the RONSON TOASTER’ as it lights first-time everytime & burns very well.
The French nicked ideas from everybody, & made their own toy LeClerk that has never been tested in combat.
The Italians have an MBT ‘Lite’ based in part to Leo1, & designed for Italian conditions.
Rumour has it that where the Cholly has a BV (Boiling Vessel) for chow, the Ariete has a Cappuchino machine?
Well I come from a country that produces no tanks, just LAV III (now that item surprised me as I thought we got those from the US, it turns out they get them from us, take off the Turrent and called it a Stryker) so I really don’t have a p iss ing match to get into. Our forces use the Leopard tank and I was wondering how it stacked up against other tanks. I had one Canadian Forces tanker tell me that the Leopard was better than the Abrahms mainly because fuel was easier to get for the Leopard. I would have thought that survivability would have been the number one issue as I heard of an Abrahms that was hit big time and it was thought the crew were all dead, hours later a recovery crew went back and found all the crew alive, just stuck in the tank because all the hatches were jammed and they were a little pissed off. How true that is I don’t know, it is just a story that I heard.
Actually, Canada only liscense builds them. They originated in Switzerland.
"Piranha III is a family of armoured wheeled vehicles developed by Mowag Motorwagenfabriken of Switzerland, now part of General Dynamics European Land Combat Systems (ELCS).
Over 8,000 Piranha family vehicles have been ordered and delivered. General Dynamics Land Systems - Canada (formerly General Motors Defense) also produce a version of the Piranha III known as the LAV III. The vehicles are constructed in a 6×6, 8×8 and 10×10 configuration."
It isn’t a turrent either. It is a turret, without an N. Just like Abrams has no H in it.
The Abrams is a multifuel engined tank. Originally, they ran on diesel, but the army switched it to JP8 because it burns better. As a lieutenant in Germany during the Cold War, we were told that we could fuel it with whatever we could get if war broke out. It didn’t matter if it was leaded or unleaded gasoline, diesel, aviation fuel or kerosene. The turbine runs at such a high temperature that it “would burn peanut butter if you could figure out a way to pump it into the engine.”
When we switched from diesel to JP8 in 1990, other than changing the fuel filters on the fueler HEMTTs, we didn’t do anything to the tanks except disconnect the smoke generators (smoke generators simply operate by spraying diesel fuel onto the hot exhaust grills). Couldn’t do that with jet petroleum because it would flame vs. burn as white smoke. All other vehicles in the unit, HMMWVs, M113A2s, Bradleys, trucks, all ran on the same JP8 as the tanks. It’s not like we had a separate fuel supply for tanks vs. other vehicles (except for gasoline powered electric generators, they used MOGAS).
So, tell me, what would you rather have, a diesel only Leopard or an Abrams that you could pull next to just about any fuel source and top off?
OOPS![:$] I can’t even blame that spelling error on fat fingers. No where the devil did I get the idea there was an H in Abrams? Blame it on a senior moment.
You have to admit being able to eat your fuel would be a pretty good thing when you got hungry, I suppose running on Vodka wouldn’t be bad either. Sure tastes better than diesel fuel.
The M1 has proven pretty survivable in combat (one of its primary design criteria), suffering far more losses from “friendly fire” as opposed to enemy action. Battlefield ID was a bit more of a problem in 1991. And nearly every Abrams knocked out was recovered and restored back in service. Hardly a “Ronson Toaster”. I don’t know who calls it that, but it’s not the users.
But yes, of Modern MBTs that have seen tank vs tank combat, the top three would have to be the Abrams. Challengers, and Merkavas. Take your pick for personal choices of the virtues of the individual design.
