I need some tips about painting models with Tamiya acrylics.
When I became a reborn scale modeller last year, I decided to use paint brushes with acrylics, which I learned would dry faster than enamels and make clean-up easier. (I don’t have room enough in my apartment for an airbrush set-up, which in any case wouldn’t help with much of my painting of details.)
Here’s a current photo of the model of the hospital ship SS Hope which I am building as USS Repose; I am not very happy with the results so far. Note that the decks are not yet glued together, or attached to the hull:
I made a couple of mistakes:
• After priming with Tamiya spray primer, I painted the decks with Tamiya acrylics, light tan to simulate areas with wood decking planks and dark grey to simulate the painted areas (the helicopter landing platform, the foredeck, and the weather deck). Some of the tan and grey paint inevitably got on the bulkheads and the many small details such as ventilators molded into the deck; I have fairly steady hands, but obviously not steady enough. And the bulkheads and deck details don’t generally meet the deck with a clean right angle, but with a bit of a curve, which helps the paint to flow onto the uprights.
• Next I painted the bulkheads, the railings, and small deck details white, inevitably getting white on the decking, which required repainting the decks. Inevitably, I got dark paint on the previously all-white bulkheads, which now need to be touched up with white, a tough thing to do over dark paint. (I have a variety of high quality brushes in various sizes and shapes, so that’s not the problem.)
I’ll continue with this project, accepting that it’s not a well-designed, cleanly molded model. It certainly looks better than it did. But as I said, I could use some tips:
• I find the acrylic paint difficult to manage. If too thick, it doesn’t dry smoothly. If I add thinner, it gets too thin and doesn’t cover well. Any suggestions?
• My paint doesn’t seem to dry thoroughly as quickly as it should. Last night, I tried painting grey paint over a previous coat of grey because it hadn’t hidden the white paint beneath, but the new grey paint lifted off the previous coat of grey. Each of the earlier coats had dried for a full day. We are having very high humidity, currently 90% here in Vancouver, which may explain that problem; I understand that acrylic paint absorbs moisture from the air.
I think I should have done some things differenly:
• I should have first sprayed the main deck and everything above, including deck details, with Tamiya white spray paint.
• Next, I should have painted the deck surfaces with the tan and dark grey acrylic, obviously as carefully as possible to avoid getting it on the bulkheads and deck equipment. (Masking the small detail parts would be almost impossible.)
I would greatly appreciate any suggestions on how to avoid the problems I’ve outlined.
Bob
