i have a question for you guys who have built beach Dioramas, what products did you use for sand? I find searching the site here difficult on my iPad. I want to put together a little 1/35 scale Normandy diorama with some figures and beach obstacles. Thanks for any help you can offer and send me in the right direction
In response to your inquiry; a fellow modeler friend of mine did a small vignette of the Normandy beach area. For his groundwork/sand he used Epoxy wood filler. According to him it gives you time to sculpt or move the epoxy around to your desired look but once it dries, it dries hard to sand or shape. This is how it initially looked. Good luck.
I do the same as dpty_dawg_ca, but use fine playground sand, chinchilla sand, or even backing powder. You just want something to give a fine sand texture.
thanks guys, yeah it’s just going to be a small scene with a few soldiers behind some obstacles. I’m also trying to figure out what I want to use for water.
Hera at the Train Museum, we use Aquarium Sand, “Fine” to do that. Then mix it in a slurry-More sand than White Glue (Aleen’s,“Tacky Glue-Gold Bottle”) Make sure you can spread it with a small putty knife or as our Marilyn prefers, A butter knife, For smoother sand use a putty knife and make sure you spread it finer at the waters edges. It will flow also because of the mushiness from the white glue.You can always go back afterwards with 180Grit sandpaper, then 320 grit paper to work the edges.
