Beach building tips
Im trying to produce a diorama of a beach. Has anybody got any tips on producing realistic sand. Im thinking normal modelling clay, which will be easy to add puddles, footprints, etc, but how to get that flat, shiny, wet look…if you know what I mean?
Modeling clay as in the sculptable kind that will not ‘set’ or harden over time? This may not be the best material as over time paint may crack and if bumped it will leave undesirable marks.
Try a fine tile grout. It has a long set time to get everything sculpted and will have the right texture. Get a light color or even a sand colored one. Use a tile up-side down as a base, wood will warp as the grout is activated with water. Once hardened nothing will touch it accept diamond tipped drill bits so be sure of sculpt before allowing to set.
Once the color is down (hopefully the grout is the correct hue) the wet sand or band where waves have soaked is much darker than dry sand. Color to match references and coat with Future acrylic floor polish to get a ‘shine’ at the trailing edge of wet sand and of course the water.
Future is self leveling and cannot be built up to add depth, if you need water to look 3D a after market water resin will be needed. Any model shop that carries model trains should have a 2 part water system for that effect.
Thanks fot the advice. Never thought about using tile grout, I can imagine that the texture will be just about right.
Im not so keen on the ceramic tile, as I wanted to have some drilled holes in the beach base that I could use for securing other parts of the diorama. From putting tiles up bathroom tiles, I know drilling holes is a bit risky, and also not so good for tightening up a screw or bolt. Can you use grout on other materials? Plastic with a rough surface?
Depends on the scale, but in 1/32 or smaller, just a rough paint job will do it. I use Krylon primer, which is pretty rough, then don’t sand before applying a flat sand color. That usually does the job.
Sand? Why not use the real deal? There are various grits of blasting media that one can get to replicate sand. Visit a company that does media and sand blasting…a cup full of the stuff will do you. Chances are you can scoop some from their bin or off the floor.
You could also use some sandpaper that is of a very fine grit. I’ve done that!
If you sift real sand through a nylon you get very fine sand.
Bill
